New Way help
this thread has 9 replies and has been viewed 585 times
Old 08-25-2019, 09:35:25 PM
Jeff P Smith Jeff P Smith is offline
Default New Way help
Was able to pick up this New Way 3 1/2HP Engine last week, lettered on the side it says 3 1/2HP UC, it does not have a hinged case. I looked a little but did not find a reference to a UC. I did find a M
Name:	New Way 2.jpg
ID:	342234   Click image for larger version
Name:	New Way 3.jpg
ID:	342235   Click image for larger version
Name:	new way 7.jpg
Old 08-25-2019, 09:38:00 PM
Default Re: New Way help
Also I am not sure what is missing for the timer and what is missing that would attach to this lever. Thanks for any help.
Name:	new way 5.jpg
ID:	342237   Click image for larger version
Name:	new way 4.jpg
ID:	342238   Click image for larger version
Name:	new way 6.jpg
Old 08-26-2019, 07:08:10 AM
AussieIron AussieIron is offline
The contact is all there but the insulated "blade" part may have been modified over the years. It contacts the head of the screw on the exhaust push rod to complete circuit and power buzz coil. I don't know what the bracket with the two mounting holes was for. My kero version has the same bracket. I thought it may be for a gear guard, but it is not in line with gear. See pic of my kero gear area. Mine is magneto drive, so holes were not used to hold pick up. Mine is model RC. -These are later models than the hinged crankcase ones.-Cheers, Neil.
The Following User Says Thank You to AussieIron For This Post:
Old 08-27-2019, 12:09:36 PM
Thanks Neil. I need to see if I can find a picture of the screen mesh so I know what to use. I have lubed everything and may try to start this weekend. will look on ebay for a manual and round leather belting.
Old 08-27-2019, 01:16:31 PM
joder joder is offline
Go to the download library on the newwaysatation website - you can download the manual there.
The Following User Says Thank You to joder For This Post:
Old 08-27-2019, 06:44:48 PM
Look for sewing machine round leather belting on Ebay. I can take fan guard off mine and take measurements later today. Fairly easy to make if you have right mesh. Will post tonight. -Cheers Neil.
Old 08-28-2019, 06:12:23 AM
I did take some photos, but can't get them from phone . So photo is from a horizontal New Way, but design is exactly the same. On a 4 hp, the wire frame dia. is 210mm, the slot is 75mm wide x 135mm to top of slot. Your 3 1/2 may be the same, but check hole size on your shroud. The wire is about 2.5mm dia. The mesh is about 5 or 6mm square. The wire has for little loops formed in it to attach to shroud. The mesh appears to be soldered to wire.Your shroud should have 4 mount holes to bolt screen onto. Hope this helps.
Old 08-28-2019, 12:13:16 PM
Thanks Neil. I did find the site and have been in touch with George. I will print the manual out this weekend.
I will do some converting and see about what mesh I can find, thinking the mesh is about 1/4" or so
Old 08-28-2019, 06:41:40 PM
Good luck, pleased to help, post some photos when finished!
Old 09-18-2019, 08:47:53 PM
Just remembered, some old garden sieves used that size woven mesh, that's what I used.
