8 hp associated update
this thread has 3 replies and has been viewed 437 times
Old 09-18-2019, 02:44:15 PM
Kevinrhall Kevinrhall is offline
Default 8 hp associated update
Hi , attached are photos of work on the 8hp namely the fitting of the crank back onto the base, also a couple of the carb which we have fitted , half of the body on, the bottom half to follow, not sure when we`ll be ready to run but hoping its before next year!!!
best regards Kevin.
ID:	344357   Click image for larger version
ID:	344358   Click image for larger version
ID:	344359   Click image for larger version
ID:	344360   Click image for larger version
ID:	344361   Click image for larger version
The Following 4 Users Say Thank You to Kevinrhall For This Post:
Old 09-18-2019, 02:54:16 PM
Default Re: 8 hp associated update
a few more or interest
thanks
ID:	344363   Click image for larger version
ID:	344364   Click image for larger version
The Following 2 Users Say Thank You to Kevinrhall For This Post:
Old 09-18-2019, 03:43:06 PM
StuartUK StuartUK is offline
Great work Kevin .Any idea what the purpose of that scoop is on the botttom of the mixer / carburettor ?.
The Following User Says Thank You to StuartUK For This Post:
Old 09-19-2019, 01:13:57 PM
Hi Stuart,
there are several lines of thought,one being it is for flame control on the carb, this came from an older and well respected enthusiast .,It would reduced draughts etc if caused by wind although the engine was in saw shed driving a line shaht with two benches on
Have attached photo of saw shed
6hp update Christian Berlin Hit & Miss Gas Engine Discussion 6 11-22-2009 02:48:14 PM
Update on my IHC M Ray Cardoza Hit & Miss Gas Engine Discussion 9 12-04-2008 09:42:34 PM
PE-75-update Mike Fitz Military MEP and Aircraft Gen-Sets 3 07-29-2008 02:11:59 PM
EK Update ronm Hit & Miss Gas Engine Discussion 2 02-07-2005 11:34:07 AM
20-40 Update d.j.baisch Antique Engine Archives 11 12-17-2003 12:40:49 AM
