Trailer couplers Not all the same.
this thread has 14 replies and has been viewed 1333 times
Old 12-01-2018, 03:15:07 PM
Default Trailer couplers Not all the same.
We all recognize this coupler but it turns out there are two very different types. The first one makes the nut underneath captive so it can't turn once the coupler is connected to the ball.
And one that is free to turn at any time.
The one that is "free to turn" is held by a nylon-insert lock nut but that's all. It is free to work it's way lose while you are driving. Also, if you have the coupler locked closed, or even locked to your vehicle. all it takes is a socket wrench to remove the nut and un-hitch the trailer.
Unfortunately I have one of these on a welded on coupler.
The Following 3 Users Say Thank You to Frank DeWitt For This Post:
Old 12-01-2018, 03:44:47 PM
OTTO-Sawyer's Avatar
Photo Re: Trailer couplers Not all the same.
Easy Enough to remedy even if the coupling is welded on like yours is.
Either go the Easy Route and buy another coupler to rob the inner parts out of and swap them (then resell the new one with the nylock nut put back in it) or make up a lock plate to capture the nut in the one you already have.
Or take yours apart and cross-drill it for a castle nut & cotter pin. (Won't STOP a Thief, but would at least slow them down and maybe deter them while eliminating the possibility of it loosening while driving).
Name:	Easy Fix for Welded on Coupler..jpg
Old 12-01-2018, 03:58:55 PM
Default Re: Trailer couplers Not all the same.
Spot weld the nut, as long as you never have to remove it that should do the trick.
Old 12-01-2018, 04:02:19 PM
Yes, I have ordered a "Repair kit" that contains all the parts but the coupler body. If that dosn't work I will make a plate. I just wanted to make people aware of what might be under there. The first one I messed with had the locking plate so I assumed they all did.
Old 12-01-2018, 04:06:03 PM
DaveHC DaveHC is offline
Ditto what dalmationgirl61 says , easy / quick fix . Thanks for sharing the info though .
Old 12-01-2018, 04:20:17 PM
Glenn Ayers Glenn Ayers is offline
I have NEVER heard of a nylock nut coming loose on a trailer hitch .... have you ?
I think you should be more concerned about your ball nut needing tightened ... sheesh !
"I'll have the Red Pill, thank you."
The Following 2 Users Say Thank You to Glenn Ayers For This Post:
Old 12-01-2018, 04:33:17 PM
I personally have not had a nylock nut come lose.
It's a picture from the internet, not mine.
The subject came up when a guy on another forum wrote that his coupler had come off while driving. Investigation showed no nut. When he hooked up he had jumped on the back of his trailer to confirm that it was in fact coupled.
Old 12-01-2018, 04:43:54 PM
DCamp DCamp is offline
I had one with the nylon nut come loose. I changed it for the plate lock type. Be sure to check the weight rating of the coupler and ball you are purchasing. I have seen them from 5000lb. to 10000lbs for almost the same price.
The Following User Says Thank You to DCamp For This Post:
Old 12-02-2018, 12:20:04 AM
AngolaGravely AngolaGravely is offline
http://www.bulldogproducts.net/produ...yLwoxgjUuTgU7k!
Accept no other.
I even cut off 2 brand new couplers on 2 suretrac trailers and had these welded on.
The Following 3 Users Say Thank You to AngolaGravely For This Post:
Old 12-02-2018, 07:32:18 AM
Originally Posted by AngolaGravely View Post
I have a small tilt-bed single axle with a "Bulldog"
I agree .... Best in the industry !
Old 12-02-2018, 03:39:35 AM
Power Power is offline
I have seen it happen!
2 summers ago, as some men in one of our town pickups were driving truck over curb cut to the storage area, the trailer popped off ball, blocking street. The tongue dropped and caught the street side of the concrete curb cut, breaking the safety chains, bending back the jack, and damaging the socket, which was now on the road. I helped chain the trailer up so we could drag it out of the street. We looked for parts, but never found the nut, which probably fell off a few miles back.
I looked at another trailer parked there, and saw only a nylock nut, as per Frank's picture. I was surprised, but when things are competitive bid, guess corners are cut. I told them to suggest to maintenance that they put some weld on nuts and on ball nuts. I said tell them if they ever have to remove ball or hitch lock, air axe will quickly take care of welded nuts.
What trailer(s) can haul a 1911 45hp CASE steam engine? What trailer is best? thefrendlyghost Trucks, Trailers and Hauling for Shows 29 04-20-2019 07:32:06 PM
Used oil under trailer ronny p 148 Trucks, Trailers and Hauling for Shows 7 11-15-2013 06:31:20 PM
they will never fit on the trailer Lee Werth Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 01-04-2006 07:31:32 PM
