Bombardier-Rotax 641 Twin
this thread has 6 replies and has been viewed 765 times
Old 12-29-2018, 04:52:16 PM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Photo Bombardier-Rotax 641 Twin
Todays find, a "1972" Bombardier-Rotax 641, 635cc, 41hp. Outta be a screamer.
Patrick
ID:	325366   Click image for larger version
ID:	325367   Click image for larger version
ID:	325368   Click image for larger version
The Following 4 Users Say Thank You to Nevr-Enuf-Stuf For This Post:
Old 12-29-2018, 05:03:10 PM
Default Re: Bombardier-Rotax 641 Twin
Awfull loud with that open exhaust too! you ned to run mufflers on it or you will burn out the pistons real quick!
Old 12-29-2018, 09:30:08 PM
G.M.Johnson G.M.Johnson is offline
Ahh yes, brings back memories of the good ole days and a snowsuit full of gas and fumes! The old timer snowmobilers know what I mean!
The Following 2 Users Say Thank You to G.M.Johnson For This Post:
Old 12-29-2018, 11:50:08 PM
Nathan K. Nathan K. is offline
Well that brings back memories, many involving a tow rope!. We bought an Alpine twin track that had a 640 Rotax (in pieces) with a broken crank for a project some time back that also came with a 641 Rotax crankcase assy., so with some work it was all fixed up and running great(had no problem spinning both tracks taking off). However It could not make it up and down the mountain without blowing a hole in the no. 2 piston, so after some standard pistons had to hone it oversize and then after more oversize pistons (all that where in Canada at the time!) I was getting very tired of rebuilding it!. Finally We removed the rebuilt original carb., got an adaptor and fitted a modern Mikuni carb+pump and No more problems!. The old carb. would randomly lean-out for no reason and was not noticeable till too late when wide open which with the low gearing is where you spent most of the time!, so after some good runs it was sold to erase the memories . Consider your self warned. Nathan.
The Following User Says Thank You to Nathan K. For This Post:
Old 12-30-2018, 12:18:14 PM
Jerry Jerry is offline
I have about a dozen Vintage(OLD) Snowmobile Engines if you want more
The Following User Says Thank You to Jerry For This Post:
Old 12-30-2018, 12:26:40 PM
"Jerry"- check your messages. Thanks
Patrick
Old 12-30-2018, 11:33:03 PM
ulgydog56's Avatar
ya but I love how they get up to rpm quick....
Twin City Big Twin Cam up for Sale Mark Schneider Live Auctions of Engines, Tractors and Old Iron 29 02-28-2019 12:04:46 AM
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 120 06-01-2018 09:21:55 AM
New Member of the Twin City Twin Cam Fraternity J Ware Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 22 09-06-2017 12:25:53 PM
Rotax single from '67 Ski Doo snowmobile EricR Garden Tractors and Mowers 0 05-20-2012 10:23:44 AM
Bombardier-Rotax single cylinder Jordan Small Air Cooled Gasoline Engines 4 05-11-2010 04:05:20 PM
