Kohler Magnum 18 twin backfire
this thread has 3 replies and has been viewed 436 times
Old 01-25-2019, 06:16:23 PM
miraclewhip miraclewhip is offline
Default Kohler Magnum 18 twin backfire
Engine ran strong without problems for years,then was running only on 1 cylinder.I removed head from non-firing cylinder and verified valve operation and no carbon buildup.replaced head and backfiring occurs. Engine will not start with 1 sparkplug removed ,or with both installed.Replaced plugs with new,and tried with old. No difference! Any ideas?
Old 01-26-2019, 11:30:40 AM
Tom Schaech Tom Schaech is offline
Default Re: Kohler Magnum 18 twin backfire
Several things need to be assessed here to determine the source of the problem. Do you have (or had) spark at both plugs? Did you perform a compression test on each cylinder to determine the PSI on the cylinders? Check ground wires for continuity? Is it backfiring when shutting off? These have anti-fire solenoids on the fuel bowls that have been a perennial problem-to the point where Kohler says to shut the engine off at full throttle. One coil or two? I've seen them go bad, especially if the cooling fins get clogged up and overheat the coil.
Tom
Old 01-26-2019, 07:16:44 PM
Tom,thanks for your checklist of suggestions. I opened both Valve covers and found the valve spring guide on one intake valve broken and valve retainer lying in valve chamber! Next I will check to see why the breakage occurred.
Old 01-28-2019, 04:10:05 PM
I think you've located your problem. Keep us posted!!!!
Kohler 12hp Magnum Backfire Issue Mike G Small Air Cooled Gasoline Engines 13 10-14-2014 07:13:17 PM
kohler 20 magnum problem bluefoxMI Garden Tractors and Mowers 7 12-07-2013 01:15:23 PM
Kohler Magnum 20 crankshaft seal Raymond Small Air Cooled Gasoline Engines 2 08-23-2011 10:49:12 AM
Kohler Magnum 20 gnition circuit John A Kohler Generators 1 04-26-2008 06:36:46 PM
Kohler magnum 20 John A Kohler Generators 5 04-23-2008 08:39:29 PM
