Capacity of a Dodge Dakota
this thread has 3 replies and has been viewed 2421 times
Old 09-01-2012, 10:17:01 AM
ronald morris ronald morris is offline
Default Capacity of a Dodge Dakota
Hi: recently I was in need of a mode of transportation and I happened upon an 02 2 wheel drive v6 dakota. Does any one have experience with these? Are they big enough to pull a small trailer? My dad had a 96 Dakota and it seems like it had a higher tow rating than a Ford 150, Just wondering what is posible with out over taxing the unit.
Old 09-01-2012, 11:06:26 AM
Philip Winter Philip Winter is offline
Default Re: Capacity of a Dodge Dakota
I have towed about 3K pounds on a 16' trailer with the V8 dakota. Given the choice I would not do it again. Felt like the engine was shaking, and braking left a bit to be desired. A small trailer would probably be fine though.
The Following User Says Thank You to Philip Winter For This Post:
Old 09-01-2012, 04:38:45 PM
Bob Willman Bob Willman is offline
I have a 2007 V6 Dakota. I pull a 17' house vehicle (1500 lbs) with no problem - not in sixth gear though. Gas mileage of course is significantly lower with the trailer.
Bob
WB8NQW
Old 09-01-2012, 06:22:30 PM
I have a 91 ranger v6 that i've pulled and hauled all kinds of stuff and never had a problem.
A lot is dependent on how well your trailer is balanced, and if it weighs much you really need trailer brakes. Engine size isn't a factor-that only tells you how fast you can go fast enough to get hurt
It would be a good plan to make sure you trucks brakes, tires, suspension, transmission are in good shape.
Robert
FM ZC 118 crankcase oil capacity John Drabik Hit & Miss Gas Engine Discussion 2 05-13-2012 08:35:19 PM
Oil Capacity of Onan JC MadMachinist Onan Generators 4 12-22-2011 12:10:56 AM
What is the make and capacity? gerryblackburn Generators & Electric Motors General Discussion 6 11-15-2011 11:26:18 AM
Increasing oil capacity on 8HP gen. fordiesel69 Kohler Generators 3 09-03-2007 01:37:05 PM
Oil capacity for 15.0 JC? nemiro Onan Generators 5 11-05-2006 09:30:35 PM
