Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Cylinder oiler blow back problems
this thread has 2 replies and has been viewed 1708 times
Old 09-08-2012, 06:52:25 AM
boz boz is offline
Default Cylinder oiler blow back problems
I am experiencing cylinder oiler blow back on a 1/4 scale throttle governed engine. The oiler is not straight through, it has what looks like some sort of check valve fitted but the oil still blows back up. Not sure what my options are, can anyone help ?
Old 09-08-2012, 10:58:48 AM
mike1 mike1 is offline
Default Re: Cylinder oiler blow back problems
If your oiler does have a check valve the problem may be nothing more than dirt on the check valve seating, If you can strip the valve down and give it a good cleaning it may cure the problem.
Mike.
Old 09-08-2012, 08:34:53 PM
boz boz is offline
It's not stripable Mike and it is a new oiler. All looks to be as it should. It seems the back pressure is too much for it but anything larger will be way out of scale, even if I could make it fit.
Oiler blow by relief R. Kern Hit & Miss Gas Engine Discussion 9 05-29-2008 02:36:42 PM
Oiler pipe blow back Jesse Zilafro Hit & Miss Gas Engine Discussion 6 02-16-2007 12:26:25 PM
3 hp Mc Cormick M blow back in oiler? Lenn Antique Engine Archives 5 02-17-2004 10:24:19 PM
Oiler Blow-by Smoke Antique Engine Archives 6 05-07-2003 01:47:39 PM
Oiler blow back! fixing the problem!! Adam Cottrill Antique Engine Archives 21 02-07-2002 02:00:25 AM
