Used oil under trailer
this thread has 7 replies and has been viewed 3173 times
Old 10-27-2013, 02:20:18 AM
ronny p 148 ronny p 148 is offline
Default Used oil under trailer
I want to spray my under my trailer with oil. I once sprayed a piece of machinery with used oil thinned with fuel oil rain washed it off quite easily. What can I use that will go through my weed hand pump sprayer with spray wand on it.
Ronny
Old 10-27-2013, 09:28:44 AM
Default Re: Used oil under trailer
try gear oil thinned with lacquer thinner or some other fast evaporating carrier.gear oil is designed to cling so that may work.
The Following User Says Thank You to Ed Radtke For This Post:
Old 10-27-2013, 10:28:25 AM
LCJudge LCJudge is offline
Try 1/2 pint of boiled linseed oil per thinned gallon of oil/fuel oil mix. When finished clean your sprayer with some gas or mineral spirits / paint thinner. The linseed oil wil gum up your sprayer if not cleaned good. The linseed oil will cause your mix to stick better to the wood and will waterproof it to keep it from being washed off.
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 10-28-2013, 10:19:04 AM
ListerDiesel's Avatar
If you want to rust-proof it to a degree, use one of the proper preservative oils like Shell Ensis or equivalent, or Tommy's idea with Linseed.
Used engine oil has some pretty nasty stuff in it.
Peter
Old 11-11-2013, 09:40:59 AM
Huber's Avatar
Huber Huber is offline
This Fluid film really lasts and is becoming available locally.
http://www.theruststore.com/Fluid-Film-C67.aspx
Old 11-11-2013, 12:45:48 PM
ShaneZahn ShaneZahn is offline
What are you trying to protect.?
If Metal, are you trying to prevent rusting .?
If the trailer has a wood deck. Are to trying to seal out water from the wood.?
I have a relatively new trailer. I am determined to paint the underside of the wood floor & steel cross members with an epoxy paint, before the factory paint blows off.
I used garage floor epoxy to paint the floor inside & that's holding up real good. I can wash it with soap / water & mop it dry.
Shane.
Old 11-11-2013, 03:25:58 PM
MoRo's Avatar
MoRo MoRo is offline
Kind of a spendy proposition, but how about Rhino Lining the underneath of the trailer?
Old 11-15-2013, 06:31:20 PM
vern0n's Avatar
vern0n vern0n is offline
After you spray it with used motor oil thinned with diesel, run it down a dusty road. Do this a couple of times. The dust will help the oil stay put. All my trucks have this coating, (not because I did it, but it did it naturally).
they will never fit on the trailer Lee Werth Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 01-04-2006 07:31:32 PM
What about your trailer? Tim Claremont Antique Engine Archives 19 02-19-2002 11:00:43 AM
Trailer Help Tony Pitts Trucks, Trailers and Hauling for Shows 11 10-21-2001 09:39:25 PM
