How hard is it to convert briggs and stratton engines to get rid or points.
this thread has 8 replies and has been viewed 13501 times
Old 12-21-2013, 05:27:22 PM
smokey honda smokey honda is offline
Default How hard is it to convert briggs and stratton engines to get rid or points.
I got a new magneto for my 7 HP but Iam tired of trying to connect the wires to the condensor without them breaking or loosing the spring.... ( I just did).
How do I upgrade to electronic ignition?
---------- Post added at 03:27 PM ---------- Previous post was at 03:24 PM ----------
By the way, whats the part #? It would be for a single cylinder 7HP Briggs.
Old 12-21-2013, 06:30:17 PM
Default Re: How hard is it to convert briggs and stratton engines to get rid or points.
Call the dealer and see if he has a Magnetron ignition for it.
It's dirt simple to install. Bye bye points.
Old 12-21-2013, 06:38:07 PM
Doug Tallman Doug Tallman is offline
That will only work if he has a 2 legged coil. If its a 3 legged coil, you would have to use one of the Nova or Atom ignition modules.
Old 12-21-2013, 06:56:38 PM
RSCurtis RSCurtis is offline
Magnetron will work on any aluminum engine built since 1964 if it has a two-leg armature. It will work on early cast iron engines if the flywheel is repolarized.
Old 12-21-2013, 09:25:45 PM
ShaneZahn ShaneZahn is offline
A few pointers on utube.
http://www.youtube.com/results?searc...on+engine&sm=3
Old 12-21-2013, 11:11:31 PM
manioso manioso is offline
Briggs part numbers are 398811 and 398265 and 395326. You can also use these numbers to look up aftermarket crosses to Stens, Oregon, and others.
OEM Briggs are about $40, aftermarket run $20 to $30.
You can leave the points and existing condenser in place. No need to cut wires or remove the flywheel.
I do this regularly on older Briggs 2 & 3hp (60000 and 80000) and older 4hp and 5hp (100000 and 130000). Easy, plus the Briggs solid state coils are almost bullet proof.
Old 12-22-2013, 01:38:18 PM
Steve Kunz's Avatar
Thats what I thought to, but I have a air compressor with a 5hp Brigggs, with factory solid state and I have went through 3 coils on it in about 10 years. First the factory one then 2 more from Briggs.
Steve
Old 12-23-2013, 08:06:02 PM
Exclamation Re: How hard is it to convert briggs and stratton engines to get rid or points.
NOTE: If you don't have electric start, be prepared to pull hard! Most electronic triggers need at least 700 RPM to start the engine points and coil will fire a plug at 300 RPM or less!
Old 01-08-2014, 04:11:13 PM
Gunners762 Gunners762 is offline
Just switched my old 1960's Toro snow hound over from points/condenser to a Magnetron .. Run me around $40.00+ for the magnetron ..
Briggs And Stratton engines finn37 Hit & Miss Gas Engine Discussion 0 08-21-2012 09:05:07 AM
Picked up 3 new Briggs & Stratton engines Bigjoedo Small Air Cooled Gasoline Engines 2 08-02-2011 10:28:27 PM
I dont get it... Why Briggs and Stratton engines? shanelc50 Hit & Miss Gas Engine Discussion 38 11-16-2009 01:13:31 PM
Vintage Briggs & Stratton Engines Bill Sherlock Small Air Cooled Gasoline Engines 18 02-05-2009 03:56:33 PM
Briggs & Stratton WI Engines actionhac Small Air Cooled Gasoline Engines 1 08-17-2007 09:36:02 AM
