Timing a mag on easy washer engine
this thread has 1 replies and has been viewed 794 times
Old 09-26-2016, 09:25:19 AM
Tim Venetis Tim Venetis is offline
Default Timing a mag on easy washer engine
I have a mag on mhy easy washing machine engine and the mag gear slid on the shaft away from the crank gear. The fiber gear has a mark on it but no mark on the other gear and was wondering how to time the mag. Also how do you adjust exhaust valve on the engine thank you
Old 02-03-2019, 12:45:51 AM
Jonathonwhite454 Jonathonwhite454 is offline
Default Re: Timing a mag on easy washer engine
do you still have this easy engine with the mag? I also have one I think but parts are missing for the ignition system. if you still have this can you send me pics of it?
Easy Washer Engine Ken Karrow Antique Washing Machines 3 09-17-2017 10:42:39 PM
Coil sollution for easy washer engine Tim Venetis Antique Washing Machines 1 01-23-2016 12:58:26 PM
Leather coupling for Easy washer jdrj4 Antique Washing Machines 3 07-08-2014 04:31:09 PM
Easy Washer Engine Junkologist Small Air Cooled Gasoline Engines 10 09-01-2009 09:01:04 PM
Easy Washer R Information needed! Robert Green Small Air Cooled Gasoline Engines 0 07-11-2009 08:57:28 PM
