Bosch generator with sachs two stroke
this thread has 18 replies and has been viewed 1061 times
Old 12-08-2018, 11:19:31 AM
timbo917 timbo917 is offline
Default Bosch generator with sachs two stroke
Hello,
I have a Bosch generator set powred by a sachs 273cc engine.
Now the engine is not that good anymore and I would like to change it for a
briggs engine. I have been trying to separate the engine from the generator but
it has me puzzled. The crankshaft of the engine slides in the shaft of the generator. The bolts that hold the two together are on the inside of the generator front flange. So you can't access them. So I took the generator appart to see if I could reach them from there but the cooling fan is in the way.
Somebody got an idea?
ID:	324129   Click image for larger version
ID:	324130   Click image for larger version
Old 12-08-2018, 02:46:42 PM
John Newman, Jr.'s Avatar
Default Re: Bosch generator with sachs two stroke
The normal method of connecting the engine crankshaft to the generator rotor is with a long bolt through the center of the generator rotor that screws into the end of the crankshaft. The rotor fits on the crankshaft with a tapered connector. You need to remove the through bolt and then get the rotor separated from the crankshaft. This may come apart easily and it may not...
Generally a soft face mallet strike to the rotor laminations will get the two to separate. If the connection is rusted, it may take more effort to separate them. Do not damage the rotor laminations.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 12-08-2018, 05:01:17 PM
Exclamation Re: Bosch generator with sachs two stroke
What is wrong with the 2 stroke? Depending on the generator, you may end up with a voltage/current ripple as you are reducing the number of power strokes by 1/2.
Old 12-09-2018, 05:47:17 AM
Hey John,thanks for the tip. There is a bolt head on the end of the rotor. I tought it held the rear bearing in place. I wil give it a try this evening. The engine is worn out so I would like to replace it with a 4 stroke. How can I tell this would be a problem with the generator?
Tim
Old 12-09-2018, 12:53:41 PM
Is this unit 50 Hz or 60 Hz?
Second, is it 3000/3600 RPM (50/60Hz)?
Or is it 1500/1800 RPM (50/60 Hz)?
If it is the lower speed, then going to a 4-stroke engine might require a larger engine than necessary due to the reduced HP available at the lower RPM. This could also cause flickering of lights as the time between power pulses is greater.
If it is a higher speed unit, then I don't see any problems with changing to a 4-stroke engine. You will need an engine with a tapered crankshaft end to mate with the generator.
John Newman, Jr.
Saint Louis, MO
Old 12-09-2018, 01:13:00 PM
Hello,
It is a 3000 rpm 50 hz.
The generator is a 5KVA unit. I have a 11 HP briggs.
Normaly that should be more than enough,somebody told me the sachs engine is was 8 or 9 HP;
Old 12-09-2018, 03:44:14 PM
Success,got them appart.
Old 12-09-2018, 04:31:55 PM
Good!
General practice is to have 2 HP of engine for each 1000 Watts of generator. Your 11 HP engine should be good for 5500 watts.
Let us know how things work out and include pictures. We like pictures!
John Newman, Jr.
Saint Louis, MO
Old 12-09-2018, 05:02:38 PM
The generator won't be a direct fit to the briggs engine.
I wil have to do some machining to fit a front bearing in the generator flange.
I was thinking to use the kind of coupling that you sometimes see connecting electromotor and pump. Don't know how its named. Wil post some pics in the future.
Old 12-09-2018, 05:33:33 PM
Vanman Vanman is offline
The Sachs engine is not rebuildable? To me that Two Stroke is the interesting part of the set. There are already oodles of run of the mill Briggs powered sets, screaming along at 3600 or 3000 rpm.
Otherwise, I'd be inclined to make the generator belt drive, to get the engine speed down to something pleasant. Here I have a Wisconsin engine running 2400 rpm. https://m.youtube.com/watch?v=6hvpFM8-qiU
Old 12-09-2018, 06:29:40 PM
The coupling you’re looking for is called a ‘LoveJoy’ coupler.
Here is a recent thread about just such a project:
https://www.smokstak.com/forum/showthread.php?t=183130
John Newman, Jr.
Saint Louis, MO
Old 12-09-2018, 06:49:26 PM
I realy don't want to rebuild the engine. It also does 3000 rpm,it smokes,is heavy end uses a lot of fuel. Not so easy to get spares to. I am planning to use this generator frequently so the briggs seems a better choice for me. I had been thinking about lowering the RPM with belt drive but I am worried the engine won't have enough power to pull the load.
Old 12-09-2018, 09:41:08 PM
Good point about the hp. If the engine is 11 hp @ 3600 rpm, it ought to be around 9 hp or a bit more @ 3000 rpm. And if the generator is 5 kW, it ought to take maybe as much as 8 hp to drive it. Leaving you with a little reserve, which is always good practice.
In my case the generator is only 2 kW. The Wisconsin will actually pull 3 kW out of the set up I have.
Old 12-10-2018, 04:21:34 PM
It is a balancing act to match engine HP to generator output.
Too much HP and you will be melting the generator into a pool of copper as the engine sings merrily along.
Too little HP and the engine will stall out before you get maximum usable wattage from the generator.
John Newman, Jr.
Saint Louis, MO
Old 12-10-2018, 04:54:01 PM
But not if you don't overload the generator.
Old 01-17-2019, 06:46:38 PM
I made good progress the last couple of evenings. The aluminium part to hold the front bearing is machined and the generator is back together. It turns smoothly and I think it wil work just fine. I also machined a shaft with a tapered end to take the lovejoy coupler. Just need to buy the coupler and adjust the mountings on the frame and I can give it a test run. Need to find some carbon brushes to,I broke two when taking the generator appart.
Wil try to take some pictures tomorow and post them.
Tim
Old 01-18-2019, 11:31:09 AM
I have been thinking and changed my mind about the use off the lovejoy coupler. They are not cheap. I going to remove the crankshaft from the briggs engine an turn a taper on the end of it. The shaft is long enough and so it wil fit
directly in the generator shaft. Wil be simpler this way.
The Following User Says Thank You to timbo917 For This Post:
Old 01-18-2019, 01:39:38 PM
Probably a good idea. The one time I saw an emgine driving a generator through a Lovejoy coupler it rattled like mad and the project was quickly abandoned.
The generator forms part of the system's flywheel, and so torque between it and the engine is constantly reversing between power strokes. It must be a ridgid connection (ideally), an adequately resiliant coupling, or (possibly) a coupling with some "spring" in it, so long as the resulting natural frequency is avoided.
Old 01-18-2019, 01:56:30 PM
Personally, I would not run a generator thru a lovejoy. It would hammer itself to bits in short order!
Fichtel & Sachs 2 Stroke Nevr-Enuf-Stuf Small Air Cooled Gasoline Engines 2 08-03-2018 09:50:35 AM
Tiny 2 stroke? What is this? A generator? Motorguy1996 Small Air Cooled Gasoline Engines 1 09-25-2016 09:59:21 PM
two stroke diesel help sachs 600 21avery Hit & Miss Gas Engine Discussion 1 05-03-2016 01:05:53 AM
2 stroke generator 750 W parts? Otpco Generators & Electric Motors General Discussion 6 05-02-2013 05:51:59 AM
DKW 462 2 stroke/ LG3000 65v 46a 3000w generator Gordon R. Generators & Electric Motors General Discussion 5 12-02-2004 01:48:09 PM
