Mystery Frankenstein Engine
this thread has 13 replies and has been viewed 1848 times
Old 12-17-2018, 05:27:46 PM
MidgetHead MidgetHead is offline
Photo Mystery Frankenstein Engine
Hopefully this is an appropriate place for this type of engine, seemed to fit best with this forum from what I can tell.
I recently inherited what could be a fun and unique or terrible project. So far through hunting for images and information on engines I have not been able to tell anything about the parts on the engine other than it looks.. homegrown. The closest match I have seen is something from Villiers, but doubtful it would have been from the UK based on time period.
A few things I do know:
-Air Cooled
-2-Stroke
-Last time run was before 1960 (Est mid 50s)
Haven't been able to find any numbers on anything, once things warm up I want to de-grease it really good and see if there's anything numbers on any of the parts. Since there is some homegrown intake manifold to a carburetor that isn't there, it leads me to think the cylinders were originally vertical, otherwise why wouldn't gramps have just used original carbs? Thinking maybe he took the upper half of 4 scooter engines and some Frankenstein love and voila!??
Anyone good at puzzles???
ID:	324605   Click image for larger version
The Following 4 Users Say Thank You to MidgetHead For This Post:
Old 12-17-2018, 06:08:58 PM
Default Re: Mystery Frankenstein Engine
Forgot to slip one in of the bottom. It's a bit blurry but at least you can see some detail of the exhaust ports.
Old 12-17-2018, 07:40:41 PM
What is it installed in?
Old 12-17-2018, 08:16:12 PM
grega's Avatar
grega grega is offline
Possibly a McCullough drone engine.
-Greg
"There only origionial once"
Old 12-17-2018, 09:14:54 PM
What is it used in. Zoom out and take some pics.
Old 12-18-2018, 12:23:45 AM
ulgydog56's Avatar
Talking Re: Mystery Frankenstein Engine
yes I would say that's some kind of aircraft engine
Old 12-18-2018, 02:34:37 PM
Thumbs up Re: Mystery Frankenstein Engine
I agree with the other posters, it is a drone engine. it was used by the military to train gunners to shoot down a flying plane. VERY INTERESTING! Sure would sound neat running I bet. it probably takes 16:1 fuel to oil ratio, and I wouldn't run it long uless you find a prop to cool the engine. You probably would find one at a model shop that deals with giant sized model aircraft, ot a fire department supply that deals with engine powered ventilating fans. I'm quite sure you could make up a manifold and find a carburetor to run it.
Sure looks like a neat find! As others have oted - is it mouted in something or is it just laying loose?
Old 12-27-2018, 04:49:25 AM
This may add to the mystery or make it a bust. I was hesitant to post what it was in because it was told it was two twins cobbled together (but no one knows) It is mounted in what I was told was a micro midget/quarter midget. Except the wheelbase is too long, so I dont know what this thing is. Closest guess is a TQ midget(?) But still dont know. Last est running was 1958, so the engine is pre that date.
ID:	325201   Click image for larger version
The Following 3 Users Say Thank You to MidgetHead For This Post:
Old 12-28-2018, 01:25:14 AM
the paint on the botom view looks like homelite green.
Old 12-28-2018, 01:39:37 PM
John Newman Jr.'s Avatar
John Newman Jr. John Newman Jr. is offline
Here is a 2 cylinder version being assembled.
The young lady went on to become quite famous.
Name:	Norma Jean Drone Builder.jpg
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 01-02-2019, 07:28:39 PM
So is the thought that some of the parts are off a drone engine? Because the heads and jugs don't look like hers in the picture?
I wouldn't think gramps would get ALL different parts and put them together but I certainly am beginning to wonder. The head and jugs both look rather aerodynamic to be off a stationery engine, so I'm still wondering if it's an old motorcycle/scooter or aviation engine.
Would this topic get more traction in the Antique Gas Engines/Mystery Engines? I also might have a lead on some local ex-midget racers that are pretty knowledgeable so I might have some new information from them as well.
Thanks for all the help and suggestions so far!
The Following User Says Thank You to MidgetHead For This Post:
Old 01-03-2019, 01:26:21 AM
stufforbud stufforbud is offline
I had on of the 4 cyl. drones that as far as I know had never been run. I found a prop for it and built an adapter from it's 3 point mounting lugs to fit my 2" hitch receiver on my truck. It was not to difficult to adapt an old carb out of my pile to replace the fixed speed unit on the engine. Got the mag working, got the fuel pump working, mounted it on the back of the truck and tried the flip the prop and fire it up. Didn't take me long to figure out that they must have used power starters on the end of the crank as all I could get out of it was a few pops and some nearly amputated fingers. Not nearly enough flywheel effect on one of these for the firing cylinder to carry the next one thru the compression stroke.
I believe they need inertia to start. I figured I better sell while I still had all my fingers.
The Following User Says Thank You to stufforbud For This Post:
Old 01-03-2019, 04:36:57 PM
CharlieB CharlieB is offline
https://www.youtube.com/watch?v=B7Bs3-mwEYA
The Following User Says Thank You to CharlieB For This Post:
Old 01-03-2019, 05:30:45 PM
Ryan Anderson Ryan Anderson is offline
Intentional or not, that gave me the biggest laugh of the day!
The Following User Says Thank You to Ryan Anderson For This Post:
Mystery Engine Nevr-Enuf-Stuf Small Air Cooled Gasoline Engines 11 10-17-2018 06:45:21 PM
HELP to ID MYSTERY ENGINE Eric McKenna Hit & Miss Gas Engine Discussion 2 04-30-2018 03:29:04 PM
Frankenstein engine MarkBillesbach Hit & Miss Gas Engine Discussion 3 10-05-2009 11:33:09 PM
Another mystery engine Patrick M Livingstone Hit & Miss Gas Engine Discussion 3 02-13-2007 09:51:23 PM
Mystery Engine Bob Naske Antique Engine Archives 2 09-07-2004 03:50:29 PM
