Nelson Model: HB Fuel Pump Issues
this thread has 5 replies and has been viewed 440 times
Old 02-02-2019, 08:43:41 PM
StormyWater9 StormyWater9 is offline
Default Nelson Model: HB Fuel Pump Issues
About a year-and-a-half ago, my dad's long-time friend, dropped the single cylinder horizontal motor off at my house, and any experience person in the field of antique engines I asked, no one knew anything about it. Finally I made my way to a guy that runs a tractor club, and one of my grandfathers long time friends. He said it was a Nelson. After many hours of finding nothing on this make, I finally found out that it was a Nelson HB. After doing a lot of work on it at that same tractor club, we managed to fix everything but the ignition and the fuel pump. I have sent out the ignition to be rebuilt by someone who hopefully knows enough about it, but no one knew anything about the fuel pump. no one understands it because as far as anyone can tell, it has everything that it needs to work, but even with a full tank it doesn't pump gas. I'm not sure if it's supposed to come out like the oil pump does, thighs much as we can see, it has a ball valve and a hole in the side for the gas to go when the plunger comes down and closes the ball valve. It also kind of looks like there should be a seal around the plunger, but when we tried an o-ring that fit almost perfectly, it still wouldn't pump gas so I don't know if that's the issue. Does anyone have any ideas?
ID:	327790   Click image for larger version
ID:	327791   Click image for larger version
Old 02-02-2019, 09:20:22 PM
grega's Avatar
grega grega is online now
Default Re: Nelson Model: HB Fuel Pump Issues
I have one that’s apart; give me a few days and hopefully I’ll remember to take a look at it.
-Greg
"There only origionial once"
Old 02-02-2019, 09:33:54 PM
Thanks! I look forward to hearing from you!
Old 02-03-2019, 01:36:08 AM
Junkologist's Avatar
It’s been a long time since I had mine apart, but I think there are two ball check valves incorporated in the fuel pump. One to keep from pushing gas back in the tank and the other to keep from drawing gas backward from the outlet.
Mike
SmokStak member #146
Old 02-03-2019, 07:58:58 AM
Was the second one in the side of the pump housing? It looks like there is room for one there, but it might need to be held with a spring to stop it from falling out of it's seat.
Old 02-05-2019, 12:08:57 AM
Ogrebeast64 Ogrebeast64 is offline
I found THIS here on the boards. I hope it helps you out some regarding the check balls.
Onan 15.0 RDJC Fuel Transfer Pump Issues RRT74 Onan Generators 4 05-28-2018 10:00:55 PM
12.0DJC Fuel Pump issues Dslsmoke Onan Generators 2 05-23-2017 10:46:31 AM
Nelson Brothers 5/8hp. Fuel pump removal? Dennis Wyatt Small Air Cooled Gasoline Engines 3 10-08-2014 07:05:18 AM
Nelson Bros. fuel pump question Everett Hayden Small Air Cooled Gasoline Engines 13 10-28-2013 11:05:23 AM
1-1/2hp M fuel pump issues Jim Scott Hit & Miss Gas Engine Discussion 8 02-13-2005 07:45:50 PM
