Briggs 10T502 Service Manual ?
this thread has 7 replies and has been viewed 433 times
Old 03-02-2019, 05:13:47 AM
cancunia cancunia is offline
Default Briggs 10T502 Service Manual ?
It's been a while since I posted on the forum, so if my post is in the wrong place apologies.
I've just bought an old-ish mower with a Briggs Engine that's not been run for a while so I'm looking for the service manual & hoped someone on here would be able to help. I can get the parts list & user guide from the Briggs site so it's just the service manual I need.
The full engine number is: 10T502-0188-B1
I think the manual reference number is 270962 which looks to be a generic L Head manual, if anyone has a copy they can share it'd be much appreciated.
Old 03-02-2019, 06:04:52 AM
Default Re: Briggs 10T502 Service Manual ?
Just googled it and a pdf link popped right up.....
scratch that. That pdf just refers to that number. Everyone seems to want to sell it.
Doc
Old 03-02-2019, 06:59:39 AM
Yep, that's what I found too. I'm hoping that someone has a working link, or a copy that they could share with me.
Old 03-03-2019, 05:13:10 AM
Thanks to Bruce for his help.
The engine on my 'new to me' mower has the most fearsome kick-back I've ever known on a rope pull / recoil starter. Hopefully, I think it's due mainly to my running it without the blade. I've since read that it's not a good idea as the flywheel is light on mower engines to make up for the blade weight.
I've ordered a new spark plug as I think the old one is faulty and will re-attach the blade when the plug arrives before trying to start it again.
This is my first 'modern' vertical shaft briggs, after having a couple of horizontal shaft engines from the 60's & 70's, never too late to learn!
The Following User Says Thank You to cancunia For This Post:
Old 03-03-2019, 05:41:57 AM
If you are getting kick back, I'd yank flywheel and check key isn't partially or completely sheared.
Doc
Old 03-03-2019, 06:09:29 AM
Doc
Yeah, that's the next on the list if re-fitting the blade doesn't do the trick. I took the blade off to check the roller drive belt & left it off while I cleaned & dried the belt cover. In addition to the kickback, the engine hunts quite badly, but again maybe the blade affects that.
Old 03-03-2019, 11:17:29 AM
gdstew gdstew is offline
I "fixed" many mowers by tightening up 1 bolt, the blade needs to be on. Also get carb diaphragm 795083 (or 795803 I don't remember) it will need replaced. When you remove the carb from the tank, you will see at the back where the diaphragm has "puckered". B & S needed another screw back there. This is a very common problem with those primer carbs, needs fixed every few years.
Old 03-09-2019, 02:02:11 PM
A quick note to say thanks to all those that responded to my thread. I put a new gasket & diaphragm in the carb, refitted the mower blade, put in a new plug and it started straight away without kickback & ran without hunting. Time will tell if the cheap diaphragm lasts the season, but at least I know what to look for if it goes again.
Onan NH-MS / 1918c Owners Manual/service Manual? Help Max Payne Onan Generators 2 01-31-2016 08:41:41 PM
Briggs 8HP 141300 Service Manual? cancunia Small Air Cooled Gasoline Engines 4 03-08-2014 08:08:50 PM
Need Manual Onan 6.5NHE 1R/26101A SERVICE MANUAL FunDay Onan Generators 13 06-16-2012 12:21:55 PM
Briggs Service Manual robert hamilton Small Air Cooled Gasoline Engines 3 05-25-2012 01:32:01 AM
Need Service Manual O/Manual/parts manual in PDF Lawdawg Onan Generators 2 09-04-2010 07:24:39 PM
