What motor would have been on this Hardie Sprayer?
this thread has 6 replies and has been viewed 501 times
Old 03-02-2019, 04:44:14 PM
Sharp Tungsten Sharp Tungsten is offline
Default What motor would have been on this Hardie Sprayer?
Recently picked up this sprayer and would like to know what type of engine originally came on It? Thank you in advance
ID:	329737   Click image for larger version
ID:	329738   Click image for larger version
Old 03-02-2019, 05:07:31 PM
Exclamation Re: What motor would have been on this Hardie Sprayer?
Hercules built 11/2 HP model GH. Built under the Arco label, these hit and miss engines are still around, you just have to look for them. Not much different than and Hercules engine with the exception of a tin cover on the crankcase to enclose the crankcase. More often than not, these tin covers are mising. They are not nescessary for the engine to run, they kept dust and pesticides out and spent oil and grease in.
As for the rig in your photo - looks like it had an electric motor on it, not an engine - perhaps a repurposed frame?
Old 03-02-2019, 05:56:43 PM
Default Re: What motor would have been on this Hardie Sprayer?
Thank you for reply. What year would something like this be?
Old 03-02-2019, 08:10:54 PM
We were a Hardie dealer back in the days. All the units we serviced were orange in color. That unit is a model 99. We put a 1 horse power electric motor on one and made a pressure (400 PSI) washer out of it.
Old 03-02-2019, 09:02:19 PM
Junkologist's Avatar
I think your sprayer probably had a Briggs & Stratton model A engine on it. I had one like it years ago.
Mike
SmokStak member #146
Old 03-04-2019, 09:01:19 AM
Andy Williams Andy Williams is offline
I also think a B&S i've seen some not sure of model A, B, Z , this one is newer than the ones with the arco engines.
Old 03-05-2019, 07:27:30 PM
Our engine club (NJAEMC) has one on a steel frame with the ARCO engine on it. Circa 1927 Low speed high pressure unit. it was used to spray an apple orchard, and could reach 35 feet in the air!
old Hardie motor (engine?) Orchard sprayer...please help ID Mistyinthemountains Multi-Cylinder Stationary Gasoline Engines and Power Units 10 01-19-2019 10:00:49 PM
Hardie Orchard Sprayer jboyer1028 Hit & Miss Gas Engine Discussion 2 01-30-2018 09:06:46 PM
Hardie Orchard Sprayer kdrider Farm Antiques and Collectibles 2 01-24-2018 06:54:52 PM
Hardie Orchard Sprayer charles ohara Farm Antiques and Collectibles 3 12-11-2013 02:48:52 AM
