Mystery Briggs
this thread has 4 replies and has been viewed 486 times
Old 03-04-2019, 07:12:52 PM
tscjcampbell tscjcampbell is offline
Default Mystery Briggs
Hello,
My father has a Briggs engine off of a David Bradley and we are wondering what model and year it is. David Bradley number 500-306126, serial number 454177.
Thank you.
Tim
The Following User Says Thank You to tscjcampbell For This Post:
Old 03-04-2019, 07:14:31 PM
Junkologist's Avatar
Default Re: Mystery Briggs
A photo of the engine would help tremendously.
Mike
SmokStak member #146
Old 03-04-2019, 08:32:29 PM
Partsman Partsman is offline
Card Sponsor
The 306126 is the type number and that translates to a model N. So if you need parts the model is a, model N type 306126.
The Following User Says Thank You to Partsman For This Post:
Old 03-04-2019, 08:51:07 PM
Here are a couple pictures.
ID:	329977   Click image for larger version
Old 03-04-2019, 09:36:41 PM
Mike in NC's Avatar
Your engine is as said a model N and was made in 1946.
Briggs & Stratton 6 Digit Type Numbers
Briggs & Stratton Model N Serial Number List
SmokStak Member #28
The Following User Says Thank You to Mike in NC For This Post:
Mustie1 Works On Mystery Briggs Thaumaturge YouTube Old Iron Videos 2 12-17-2018 03:04:03 PM
Briggs Model H Carb Idle Adjust Mystery KD5BYB Small Air Cooled Gasoline Engines 10 05-10-2011 09:07:30 PM
Need help w/Briggs mystery Chris Kirk Small Air Cooled Gasoline Engines 14 05-27-2010 12:38:07 PM
Briggs 5S Mystery Frank Douglas Small Air Cooled Gasoline Engines 4 09-01-2005 11:24:04 AM
