Briggs & Stratton FH Flywheel
this thread has 5 replies and has been viewed 545 times
Old 03-07-2019, 01:43:54 AM
60Chevyc10 60Chevyc10 is offline
Default Briggs & Stratton FH Flywheel
I need good flywheel for 1927 FH engine.
Old 03-07-2019, 01:49:25 AM
Default Re: Briggs & Stratton FH flywheel
I know the feeling, I need one too, and a backing plate. It seems the metal was a poor quality and it distorted and warped and cracked over the years. I have a 29 and a 31 I think it is. The 29 runs great, or it did a year ago anyway. The other one, I have thrown money at it like firewood in a stove and that backing plate just keeps warping and the flywheel rubs it.
I repaired the carb on it back when the throttle pieces were reproduced. That was 85 bucks, time I bought the 75 dollar throttle and then the 10 dollar rivets on eBay.
Old 03-07-2019, 08:09:49 AM
Mike in NC's Avatar
Post an ad in the Wanted section on EnginAds
EnginAds
SmokStak Member #28
Old 03-07-2019, 03:48:11 PM
Default Re: Briggs & Stratton FH Flywheel
And look to the sponsor pages for small engine parts.
Old 03-07-2019, 11:51:47 PM
OK thanks
---------- Post added at 07:51:47 PM ---------- Previous post was at 07:49:38 PM ----------
OK Thanks
Old 03-08-2019, 01:52:15 PM
G.M.Johnson G.M.Johnson is offline
I ended up making a mandrel so I can chuck the flywheel's up in a lathe and cut the back lip back to stop the rubbing. I also did some testing on back cutting on the warped metal that flares out around the magnets, and I even back cut the magnets themselves. I have a local balance shop that is willing to rebalance it if needed. This test flywheel pictured has not been run yet, but I do have one that I just cut the back lip back .050 and it did not affect the balance at all. The center taper as I remember correctly was 9- 9.5 degrees. As I remember the first fitting cone I cut at 9 degrees taper but the fit wasn't what I wanted so I ended up with 9.5 degrees from horizontal.
Name:	Briggs FH flywheel mandrel (1).jpg
ID:	330188   Click image for larger version
Name:	Briggs FH flywheel mandrel (2).jpg
ID:	330189   Click image for larger version
Name:	Briggs FH flywheel mandrel (3).jpg
The Following User Says Thank You to G.M.Johnson For This Post:
Briggs and Stratton Model 23A Flywheel Key GarrettM Small Air Cooled Gasoline Engines 5 09-06-2016 05:04:11 PM
Briggs and Stratton npr6 flywheel joei24 Magnetos, Ignition Coils and Spark Plugs 5 06-21-2013 11:37:12 PM
Briggs And Stratton FH Flywheel Question Drake Small Air Cooled Gasoline Engines 11 03-15-2013 05:13:42 AM
Briggs and Stratton 3hp Flywheel Mag cat2924570 Magnetos, Ignition Coils and Spark Plugs 4 05-02-2011 02:48:37 PM
Briggs & Stratton Flywheel Engine wvsky YouTube Old Iron Videos 0 04-06-2009 07:52:10 PM
