Need help with V-belt Clutch
this thread has 10 replies and has been viewed 961 times
Old 01-07-2019, 12:43:18 PM
CharlieB CharlieB is offline
Default Need help with V-belt Clutch
Just finished building a garden tractor. It has a B-section V-belt as a clutch. The clutch pulls hard with no slip and releases fully, but it grabs real hard. Impossible to feather it. Somebody told me that there are special V-belts for this application that slip just a little before fully grabbing. Anybody know more about this, or have another suggestion for making the belt clutch more user friendly?
Old 01-07-2019, 01:34:00 PM
Default Re: Need help with V-belt Clutch
Seems the cloth wrapped belts provide smooth engagement, whereas the ones with the raw rubber edge grab harshly.
I have heard that there are indeed belts designed specifically clutching operation, but these may not be necessary in your case since it is basically in or out, no slipping or accelerating a heavy load.
Old 01-07-2019, 02:40:22 PM
KevinJ KevinJ is offline
YEP, try a power equipment belt
1950 Farmall M, 1962 Farmall 560D, Kubota GL3940HSTC, Kubota B7500, Kubota BX1860, many implements, etc.
The Following User Says Thank You to KevinJ For This Post:
Old 01-07-2019, 04:01:14 PM
Exclamation Re: Need help with V-belt Clutch
Gates Green Belts - heavy duty, made to give long service.
Old 01-07-2019, 05:18:49 PM
G.M.Johnson G.M.Johnson is offline
Yep, if not try a cloth wrapped belt. I have a older Bolens that is gear drive with "belt" clutch. Works great just like it has a normal slip clutch.
The Following User Says Thank You to G.M.Johnson For This Post:
Old 01-07-2019, 09:58:40 PM
Thanks to all who replied.
The current belt is a fabric wrapped industrial belt.
As a follow-up to the information received here, I see on the Net that outdoor power equipment calls for a different fabric wrap. Blue, or green, or even Kevlar.
Most suppliers that I found stock them by the part number from the manufacturer of the machine they fit. Not good for my home-made tractor. I did find a couple of sources that stock them by belt length, which is what I need. Thanks again for the help.
Old 01-08-2019, 08:21:03 AM
MrBrown MrBrown is offline
Go to NAPA. They have a pretty good B series belts. I use one on my Woods RM 59, B-180. Mike
The Following User Says Thank You to MrBrown For This Post:
Old 01-10-2019, 09:02:29 AM
rodneyt rodneyt is offline
you could also try making a slightly oversized but neat fitting cover as used on the Howard Terrier Rotary Hoe. this photo is a bit second rate, nevermind that, zoom in and look at the belt cover hanging from the handlebar. note the extra piece of metal forming an inner flat strip along underneath what is the top edge.
in use the belt is held tight by the overcentre acting idler wheel, which pushes in from the outside underneath, as can be seen down low in front of land wheel, and the belt runs on all 3 pulleys, no friction.
when clutch activated / overcentre wheel is down, the oversized belt expands outwards, especially around the smaller engine pulley, it then rests against the inside of the outer edge of cover, including the inner top flat bit.
when the belt and belt cover are correct, the resting belt then does not touch the engine pulley at all. because of this 'holding free' feature, the gearbox has no idling motion to cause crashing of gears when changing gears. the 'belt-holding' action provides a small but effective clutch-brake action. i have never actually used one, only watched others, but i suspect that this 'holding free' allows the belt to be more smoothly engaged than an 'always-hanging-off-the-pulley' type setup. it also allows a freewheeling engine for startup.
great to hear about a homebuilt machine, best wishes, Rod.
The Following User Says Thank You to rodneyt For This Post:
Old 01-10-2019, 01:08:12 PM
HI rodneyt,
Thanks for pointing out the importance of restraining the belt away form pulley contact in the slack position. I do have restraints in place, and disengagement is 100%. Engagement is the problem. Too sudden. The 7" diameter cast iron pulleys I used may be over-design. Too much friction to allow a little slippage at low torque engagement. I'll polish the pulleys up and install a different belt, as others have suggested. If that fails, I'll need to consider different pulleys.
Old 07-25-2019, 10:12:46 PM
This is an old thread, but I need to update it out of courtesy to those who helped by replying. Life kind of got in the way of my finishing this project, but it's done now.
The 7" diameter pulleys had a light film of rust on them from storage, so I polished them up on the lathe and reinstalled them. Didn't help the problem.
Next, I installed a new Kevlar wrapped belt designed for clutching. Still no improvement.
Finally, I replaced the 7" drive pulley with a 4" pulley. That allows just enough slippage for smooth engagement, but is still strong enough to transfer the full torque of the 12HP Wisconsin without slipping when fully engaged.
The original set-up was just over-designed.
The Following User Says Thank You to CharlieB For This Post:
Old 07-25-2019, 10:34:36 PM
John Newman Jr.'s Avatar
John Newman Jr. John Newman Jr. is offline
I too have a home built tractor. 14 hp Briggs OHV vertical shaft engine. I found that the smaller the pulley on the engine, the better it will fully disengage and more control when engaging.
I have a 4” on the engine and a 12” on the transmission input shaft.
Had to fabricate guides/retainers with 1/4” round rod to keep the belt from falling off when disengaged.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
clinton 577 clutch belt Roland Tate Chain Saw Collectors 1 01-04-2014 11:30:40 PM
V belt clutch design help 73eldo Hit & Miss Gas Engine Discussion 2 09-04-2013 11:37:07 AM
John Deere styled A belt pulley /clutch abluechev81 Antique Farm Tractors 8 06-30-2009 09:22:31 PM
Flat Belt Clutch Pulley Doug Waggonner Antique Engine Archives 0 03-06-2003 06:47:38 PM
Flat belt clutch pulley Doug Waggonner Antique Engine Archives 0 03-05-2003 02:04:31 AM
