Help. Westinghouse light plant
this thread has 4 replies and has been viewed 2179 times
Old 06-09-2005, 08:28:09 PM
ECSnyder1 ECSnyder1 is offline
Default Help. Westinghouse light plant
NEED HELP !!!!!!
I have a one cyl,/aircooled 4 cycle/3 3/8" bore X 5" stroke engine.
Crank timing gear is stripped. Gear size is 3 1/4" dia. X 5/8" wide, 1 3/4"
bore with 5/32 keyway. Anybody help me ?????????
Old 06-09-2005, 09:32:44 PM
Default Re: Help. Westinghouse light plant
Number of teeth and type of gear and a picture if possible.
Jim
Old 06-10-2005, 10:55:20 PM
Chuck Woycke Chuck Woycke is offline
i also have a westinghouse light plant.model e 83 i think 2000 watt dc.i tore it apart the crank gear is shot.it,s a sprial gear made out of bakelite plastic i think they called it mycarta plastic made in 1927.i also would like to know if anyone has any crank gears for sale? i have looked at the delco lite plants they also use that type of sprial gear but it,s smaller than the west. unit.i think there gear is made out of cast iron? if anyone needs any parts let me know.it has a good cyl. head piston rod ,carb ect -chuck
Old 06-11-2005, 06:37:43 PM
I have two Model E 30, 750 watts. Bolth crankshaft gears are striped. The camshaft has pot metal bearings and with age it swells up and locks the cam up like you welded it. Some one decides to put a bar in the flywheel and make it turn over, it does, but the camshaft doesn't turn. If any one finds a source for those gears let me know.
"DELCO DON" Southern Illinois
Old 06-12-2005, 02:56:13 PM
K D Redd K D Redd is offline
I DO NOT have the parts you need, but have you done a search for a machine shop that might be able to build the gears out of something other than the O.E.M. material. You might post at www.practicalmachinist.com to find someone to make you helix gear.
Kent
Westinghouse Light Plant SteamfanMN Delco and other Low Voltage DC Light Plants 7 06-07-2015 09:23:27 PM
Westinghouse Light Plant Information Needed Dave N Antique Engine Archives 11 08-03-2014 07:46:28 PM
westinghouse light plant tim rostar Generators & Electric Motors General Discussion 1 05-31-2013 09:26:15 AM
westinghouse light plant tim rostar Delco and other Low Voltage DC Light Plants 6 08-08-2005 12:35:52 AM
Westinghouse light &power plant Chuck Franklin Generators & Electric Motors General Discussion 0 01-31-2003 09:12:07 PM
