fresh paint & clear coat
this thread has 6 replies and has been viewed 2196 times
Old 07-18-2006, 06:26:48 PM
Scott Kocher's Avatar
Scott Kocher Scott Kocher is offline
Smile fresh paint & clear coat
hello to all dose anybody on the stack use clear coat after a new paint job on ther engines or not or just paint so it gets the old look faster
Old 07-18-2006, 06:34:08 PM
Terry Beasley's Avatar
Terry Beasley Terry Beasley is offline
Default Re: fresh paint & clear coat
I never use clear on an engine but If it is in bad enough shape to need new paint I use two part urathane paint. It holds up to gas and oil.
Old 07-18-2006, 11:04:51 PM
hit-n-miss166922 hit-n-miss166922 is offline
Hello from Wisconsin!!
I have an engine that was painted about 12 years ago with "Forest Green" Rust-Olium and clear coated with Rust-Olium. The clear coat has turned "brown", and is peeling off. The green paint under the clear coat is real good. Now I have been using an air hose nozzle real close to the surface and the clear coat is comming off with little or no damage to the green paint. What a mess!! No clear coat for me!!!!!
Old 07-19-2006, 06:17:15 AM
I use Sikkens automotive acrilyc urethane two part paint. I would not be worried about useing their clear on an engine. Unless you are going for a show finish and fill the surface of the castings and sand everything really smooth I don't see where the clear would add anything.
Old 07-19-2006, 11:52:39 AM
Brad Kelley Brad Kelley is offline
hit-n-miss confirmed my suspicion. I'd be afraid it would yellow or crack.
No clearcoat on an engine, but I'd wax it real good if I was worried about the paint fading.
Old 07-19-2006, 07:26:38 PM
thank you guys for the replys you saved me a lot hassles
Old 07-20-2006, 10:52:48 PM
John Davis's Avatar
John Davis John Davis is offline
Arrow Re: fresh paint & clear coat
Skocher,
Two part automotive urethane hardner will not yellow or crack and will make the paint more durable then acrylic enamel paint or clear coat.
John
high heat clear coat paint. marathon man Paint Shop 3 02-25-2017 12:34:30 AM
Chalking Paint and Clear Coat Craig A Antique Autos and Trucks 18 06-02-2015 08:23:26 PM
Clear coat John Bunting Paint Shop 1 01-26-2004 06:00:13 PM
Clear Coat? Ron Paint Shop 2 06-09-2002 09:43:14 PM
