Ice Cream Freezer
this thread has 5 replies and has been viewed 2803 times
Old 08-16-2007, 07:05:58 PM
Jeff Conner Jeff Conner is offline
Default Ice Cream Freezer
Hi,
I have been thinking of building a 6-8 qt. ice cream freezer for years now using a Briggs FH, or a Nelson Bros. OHV engine. I finally decided that this is the year to build one. I have it pretty well figured out, but wondered if there is any recommendation for an "ideal" RPM at the freezer drive shaft. I haven't ever hand cranked a larger freezer so I am not sure. I would guess somewhere between 40 an 80 RPM would work well. Any suggestions?
Jeff
Old 08-16-2007, 08:51:31 PM
Gailey Henderson Gailey Henderson is offline
Default Re: Ice Cream Freezer
40 rpm is what i have found in researching the idea
Old 08-16-2007, 08:53:55 PM
Tom Martin Tom Martin is offline
I initially had my double 6qt running at 60rpm at the freezer, but have since slowed it down to 45rpm ,and it seems to freeze a little faster.
Old 08-16-2007, 08:57:07 PM
Byron Roberts's Avatar
Byron Roberts Byron Roberts is offline
This is one a friend built.. and added a few options....I think 60 rpms is real close to make ice cream.... http://antiquetractorforum.com/view...914a86fca3954d ....B,
Old 08-16-2007, 09:38:09 PM
Thanks. I calculated my speed with the drive I have, and I cannot get it below about 55-60 RPM. I hope that will work ok. The engine doesn't like to run much below 1200 RPM. We will see.
Jeff
Old 08-16-2007, 10:28:02 PM
Jeff
Jeff:: can you tell us what engine you are working with..1200 sounds kinda high to start out with...maybe we can slow it down...B,
Electric ice cream freezer LWCash Hit & Miss Gas Engine Discussion 0 11-30-2015 02:40:25 AM
Gas Circular Saw and Ice Cream Freezer GarysToys Hit & Miss Gas Engine Discussion 9 11-27-2014 10:46:21 PM
FH for ice cream freezer GarysToys Small Air Cooled Gasoline Engines 1 02-26-2010 01:51:21 AM
Under Construction (ice cream freezer) Tom Stahl Hit & Miss Gas Engine Discussion 12 12-24-2008 02:39:49 PM
Looking for Hit & Miss Ice Cream Freezer Al K Hit & Miss Gas Engine Discussion 4 07-11-2005 11:06:46 PM
