Please help Identify this engine
this thread has 10 replies and has been viewed 2565 times
Old 11-19-2007, 10:24:30 PM
OzEngines's Avatar
OzEngines OzEngines is offline
Default Please help Identify this engine
Can anyone please help me identify this engine, it is from a guy in the UK who needs help.
ID:	26074   Click image for larger version
Old 11-19-2007, 10:47:13 PM
Gary Gruel Gary Gruel is offline
Default Re: Please help Identify this engine please
Could it be a Wolverene by The Field and Brundage? Or Sattley?
Old 11-20-2007, 01:36:59 PM
Matt Montague Matt Montague is offline
Well, I have a Wolverene by The Field and Brundage, but it has the Sattley style sliding coller govenor. Mine has a webster. I will tell you that from what I can see, mainly the rocker arm trunion on the push rod they look close.
Sorry not much help.
Matt
Old 11-20-2007, 02:43:06 PM
Doug Kimball's Avatar
OZ,
Try this thread:
http://www.smokstak.com/forum/showthread.php?t=33009
I contacted the friend of the owner of the engine in GEM about a year ago.
I've attached three photos he sent me to this thread. He & we have not been able to come up with a definitive answer on identification.
Our emails are below:
Irvin,
A friend saw your query in the March, 2005, issue of Gas Engine Magazine regarding identity of your friend's mystery engine. I'm not sure that I can help identify it but there was an engine at the 2006 Dublin, NH show that looked very similar. I have attached two scans of this engine. The mixer shown is probably not original to this engine & I could see no mixer in the photos of your friend's engine.
Our guesses so far are possibly an early Alamo or a Field-Brundage. Does your friend's engine have grease cups or oil wells on the main bearings?
If you had a good photo & dimensions of the ignitor maybe you could identify the engine by going to this site:
http://www.oldengine.org/members/brookover/ign-id.htm
If you have identified it could you let me know?
Irvin's reply:
Thanks for sending the information on the gas engine. Over the years I have had a lot of ideas of what my engine is but nobody knows for sure. I have the big yellow book on engines and it is not in there. The pictures you sent are very similar to mine. Do you know what that engine is? I have oil wells and quite a bit of brass parts on it. My igniter is not listed on the web site. My measurements are .437 by 2.750. There are a few with the same measurements but none as complicated as mine.
Irvin
Name:	Cnv0471 (Small).JPG
ID:	26088   Click image for larger version
Name:	Cnv0957 (Small).JPG
ID:	26089   Click image for larger version
Name:	Cnv0958 (Small).JPG
Old 11-20-2007, 06:03:46 PM
OzEngines's Avatar
Here is a shot of the head and rocker, to help identify it.
Peter
ID:	26097   Click image for larger version
Old 11-21-2007, 08:22:51 AM
Edd Payne Edd Payne is offline
Just looked at all the pics of this engine and think it may be a early Alamo.My reason being the gov wt and speed adjustment.It is identical to my early vertical Alamo.The main bearing caps also look the same.
Old 06-25-2014, 05:57:18 AM
Kevbuts Kevbuts is offline
Hi All,
The engine pictured in the two photos at the top of this thread is owned by a friend of mine here in England. It was a friend of his that originally started this "identity thread" on his behalf back in 2007.
Obviously research and knowledge advances with time, so I was wondering if anyone can shed anymore light on what the engine is? Is it still thought to be of an early Alamo?
I understand that Doug Kimball has seen another example of this engine a couple of times over the last 8 years at the Dublin, NH Show. Does anyone else have one the same?
My friends engine has now had a replica J-type carburettor made for it, and it has been coaxed back to life, albeit the governor system needs a little more setting-up I understand. it is running again though which is great news.
If anyone has anymore information about these engines, or anymore photographs of other examples we would love to see them.
Many thanks,
Old 06-25-2014, 06:49:09 AM
Kev,
See this link for more photos: http://www.smokstak.com/forum/showthread.php?t=95160
I see parts that seem similar to Stover, Field Brundage, R&V and Alamo but we never identified the maker.
In Kennebunk, Maine;
Doug Kimball
The Following User Says Thank You to Doug Kimball For This Post:
Old 06-25-2014, 09:34:53 AM
Thumbs up Re: Please help Identify this engine
Hi Doug,
Thanks for the link to your previous thread. Those photos of the engine you've seen at the Dublin NH Show are great.
Particularly as the engine my friend owns needs a new fuel tank. Its nice to know what the original tank should look like.
Is the engine you've seen at The NH Show in running order? I would be interested to know if it runs as well as a hit and miss Stover W? Those engines run lovely and slow, freewheeling for many revolutions between firing.
Do you know who owns the engine you've seen at the NH Show? It would be useful to be in contact with another owner of one of these engines.
Many thanks, Kev
Old 06-25-2014, 02:57:50 PM
Kev,
I met the owner & talked with him but don't have any contact information. He is not a regular exhibitor. The engine did run, smoked a little & could have used some tweaking. If I remember correctly it had not run for several years & he brought it again to see if someone could identify it. I have some scans of photos a friend took at the Dublin show but several years prior to 2009 of the same engine.
I had some email correspondence with a mid-west collector who also had one. We exchanged photos but did not positively id it. I've attached four photos of his engine here. This one had no carb. I would say that both engines were originally painted red. Paint on neither was great but looks similar to that on old, faded Economy or other red engine.
Maybe someday someone will id them.
ID:	198680   Click image for larger version
ID:	198681   Click image for larger version
ID:	198682   Click image for larger version
Doug Kimball
Old 06-25-2014, 04:05:30 PM
Thank you for your help Doug. It's much appreciated.
Interestingly the serial number on the engine you've seen (13034) fits in nicely with the Alamo Engine Registry (http://buzzcoil.brinkster.net/alamo/page201.html). This would date the engine to around 1911 / 1912 which would fit in nicely with it's styling and features I would say.
I will try and find out what the serial number is on my friends engine to see whether this fits in with the Alamo Engine Registry, and how it compares with the Dublin NH Show engine.
As I mentioned before, my friends engine here in England has now had a replacement carburettor fabricated, and the damaged rocker arm repaired. It has been run once (several years ago), but needs some attention to the governor system to get it running nicely.
I am due to see my friend in the next couple of weeks, so will find out more about his engine then, and report back with an update.
Thanks again for your help , Kev
Need to identify this engine J Eddy Hit & Miss Gas Engine Discussion 18 07-09-2014 03:46:19 PM
the early 4th of July engine find..help identify engine. Firewoodguy Hit & Miss Gas Engine Discussion 10 07-03-2014 06:41:37 AM
Identify this engine Nick Huff Hit & Miss Gas Engine Discussion 9 12-30-2010 09:17:58 PM
Leroy Engine help! Please help me try to identify my Uncle's engine Sprintcars11 Hit & Miss Gas Engine Discussion 4 06-06-2009 11:08:59 PM
Can anyone identify this engine? whargrov Small Air Cooled Gasoline Engines 3 12-20-2008 10:24:03 PM
