Aluminum and steel?
this thread has 23 replies and has been viewed 3470 times
Old 09-13-2010, 09:49:27 AM
Tom Winland's Avatar
Tom Winland Tom Winland is offline
Thumbs down Aluminum and steel?
I'm trying to get a steel shaft the is meant to turn thru aluminum housing but sat outside for a couple years and now is stuck. What is the best way to loosen this up because I can't get it to move. Just so you know I'm working on a hit miss ice cream maker. Thanks for any help on this project because I'm trying to make ice cream this coming weekend.
Tom Winland
Ohio
http://gasenginetom.com
CHECK OUT MY ENGINE VIDEOS AT
http://www.youtube.com/user/gasenginetom
Old 09-13-2010, 10:22:32 AM
Roland Hayes Roland Hayes is offline
Default Re: Aluminum and steel ?
Hi, heat will loosen the housing. Aluminium has several times the rate of expansion of that of steel, if there is a build up corrosion inside then you will need to introduce some light oil while it is hot and work the shaft back and forth to break the grip of the oxides. Make sure that you clean the exposed part of the shaft well so that as the shaft pulls through it gets easier and easier. Aluminium has a relativley low melting point so be careful not to over do it, I always try an electric heat gun first but if that fails then the gas torch will show it who's the boss. Any process that involves fire is inherently dangerous so have a bucket of water handy to extinguish any accidental fires and wear eye protection.
The Following 5 Users Say Thank You to Roland Hayes For This Post:
Old 09-13-2010, 12:33:06 PM
Rod Fielder Rod Fielder is offline
Hey tom
heat the aluminum as roland said. As soon as you get the aluminum hot, spray it immediately with pb blaster. The heated aluminum will suck the pb blaster inside between the steel and the aluminum like, well it'll suck in right in anyway. Use vise grips on the shaft with a piece of thin rubber around the shaft in the vice grip jaws and try turning the shaft back and forth. Repeat as necessary until a loose fit is obtained. Sort of sounds like a good start for an x rated movie.
Rod
The Following 2 Users Say Thank You to Rod Fielder For This Post:
Old 09-13-2010, 12:47:08 PM
phabib phabib is offline
My dad tells a story of his journeyman project when he was completing his apprenticeship as a mechanic. There was an old car that had been outside in the back lot of the garage for a long time and the owner of the place told him how it was his and he'd never had the time to finish getting it running and he'd like to get it going again and rebuilding the head would be the final task that he'd be judged on.
End of the story is after a few days of trying everything to get the aluminum head separated from the iron block where it had welded together by electrolisys and who knows what other mechanism, the apprentice got a lesson on dissimilar metals and the car was put back in storage for use with the next apprentice.
The Following 2 Users Say Thank You to phabib For This Post:
Old 09-13-2010, 01:28:05 PM
Yeah, bin there done that, worn tee shirt and eaten the pork pie (a quaint English expression). My technique was to extract the head studs one at a time often by welding a big nut to the top of the stud for better purchase, until the head was released, this process usually involved a large consumption of oxy-acetylene gas and a great deal of cursing, foolishly I made a bit of a rep for myself as having a special technique for stubborn parts and many collegues in that line of work started bringing me their problems. It was the Mig. welding of a fairly big nut to the exposed end of the studs that really made this possible, a new set of studs and a lecture on the importance of glycol antifreeze to the owner and it was 'jobs a goodun'.
Old 09-13-2010, 03:07:18 PM
BMiller's Avatar
BMiller BMiller is offline
An older mechanic told me that one time he'd had to pull the aluminum head off an old (iron) straight-eight engine - they couldn't get it loose, so they just loosened the nuts on the studs and started the engine. It ran a few minutes and broke loose without damage.
Bill Miller
Old 09-13-2010, 03:53:33 PM
Trevor A Cole Trevor A Cole is offline
My mate chopped an aluminium head off a ford sidevalve V8 with an axe!!!
Old 09-13-2010, 04:27:35 PM
VanS VanS is offline
I've had aluminum car wheels "adhere" to the steel hubs... Loosened all the lug nuts a few turns, drove around in a parking lot zig-zagging back and forth, and got them to all break free.
Old 09-13-2010, 04:31:30 PM
C-Wade7 C-Wade7 is offline
Trevor,
Sounds like my kind of guy, I like to let this stuff know who is running the show sometimes, and thats one way to do it!!
The Following User Says Thank You to C-Wade7 For This Post:
Old 09-13-2010, 04:40:59 PM
Pete Nichols Pete Nichols is offline
Default Re: Aluminum and steel?
Rod,
Wonder if Tom is talking about at the show ?????????
If he is we'll have to make sure that we get there early .
Pete
The Following 2 Users Say Thank You to Pete Nichols For This Post:
Old 09-13-2010, 04:43:20 PM
Pete,
actually that's why I'm trying to get it going in time for the show this weekend
Tom Winland
Ohio
Old 09-13-2010, 05:03:36 PM
Tom,
I'll be there for sure !!!!!!
Pete
Old 09-13-2010, 07:45:22 PM
Me and mccray will be there also
Old 09-13-2010, 08:55:45 PM
Mike Monnier's Avatar
Hoarder
If the shaft is meant to be spinning in an aluminum housing, someone failed engineering 101. You need a bronze bearing in the housing to keep the aluminum from galling and welding itself to the shaft. I suppose the assumption is that you can get away with it for the short amount of time an ice cream freezer runs, but the bearing area better be flooded with oil.
Old 09-13-2010, 10:06:53 PM
When heating aluminum to aneal it you can soot it with acetylene and heat until the soot disappears. It would be safe to soot your tube if you're going to heat with a torch, you can't tell when aluminm is going to melt.
Old 09-14-2010, 12:05:07 AM
Daniel Dorece's Avatar
Daniel Dorece Daniel Dorece is offline
A trick we used to use to free up the aluminum heads on Ford flatheads might work here. If you can find a piece of thin wall steel tubing with the I D the same as the O D of your shaft you can cut teeth in the end of the tube, slip it over the shaft and turn the tube by hand or with a drill and cut away the aluminum around the shaft. Then after the shaft is out bore the housing for a press fit for an oilite bronze bushing which should be in there anyway. We used steel bushings on the old Ford heads and even added steel bushings to the high performance aluminum finned heads till we finally got smart and started to use aircraft grade bolts instead of studs.
Iron Wolf
The Following User Says Thank You to Daniel Dorece For This Post:
Old 09-16-2010, 08:57:32 AM
Good news it's up and running and ready to try and make ice cream. My good friend Steve fixed it up for me. I'll let him chime in and tell his secrets if he wants to. Here's a video http://www.youtube.com/user/gasengin.../0/JRDLrWGMKWs
Tom Winland
Ohio
The Following 4 Users Say Thank You to Tom Winland For This Post:
Old 09-16-2010, 09:52:08 PM
Steve Holbrook Steve Holbrook is offline
No secrets here. Just kept working on it till it freed up.
By the way, I do like Ice Cream!!!
The Following User Says Thank You to Steve Holbrook For This Post:
Old 09-16-2010, 11:22:00 PM
Randy Hart's Avatar
Randy Hart Randy Hart is offline
I went to Kidron today and picked up the mix, so it should be a go for ice cream
Now where did I put that hub cap from a 52 Buick Makes a good bowl,I like a lot of ice cream !
He who dies with the most STUFF wins!
The Following 2 Users Say Thank You to Randy Hart For This Post:
Old 09-17-2010, 12:11:02 PM
You guys makin' BEER ice cream?
Aluminum piston, aluminum cylinder? NAR Scale Model Engineering 9 03-11-2008 02:02:27 AM
Whaddya think? (steel wheels on a steel deck) MoRo Trucks, Trailers and Hauling for Shows 10 02-15-2008 05:53:33 PM
Freeing stuck steel and aluminum? FarmallIH Machine Shop and Tool Talk 4 12-07-2007 03:17:03 PM
Brass, bronze, steel and aluminum stock Sky Machine Shop and Tool Talk 2 08-27-2007 09:30:20 PM
Aluminum Vrs. Steel Steve Gerot Antique Engine Archives 5 05-09-2003 08:56:44 AM
