Alpha DeLaval Help
this thread has 3 replies and has been viewed 1444 times
Old 01-09-2011, 07:29:41 PM
BobM BobM is offline
Default Alpha DeLaval Help
was wtrying to get my alpha delaval to fire
just got earlier this year ground the valves hone the cylender
got it all cleaned up so hooked up a gas line with check valve check the igniter ok
spun it around seems gas leaking out this cross hole in the carb and not getting to the cylender
i wouldnt think this to be open like this on the carb?? but whats it for all my other carbs are different
Old 01-10-2011, 10:02:30 PM
Default Re: Alpha DeLaval Help
I hoping someone with a frost king alpha delaval could shed some light on the hole in this carb?? or what it there for
thanks folks
Old 01-10-2011, 10:31:37 PM
David M. Lyon's Avatar
I can't tell from that close up photo, but it sorta' looks like a natural gas mixer. Does it also have a gasoline line and a needle valve?...post a photo that shows the entire front of the engine.
Old 01-11-2011, 12:16:29 AM
the brass tube that going in the bottom is my gas line the fitting on the 45* is the needle adjustment
i dont know the needle valve was gummed up with gas or i thought but wouldnt the NG leak out like the like it doese reg gas
i wont get to the shop until this weekend but i get a pic
I never seen NG carb for a hit miss
---------- Post added at 10:16 PM ---------- Previous post was at 09:23 PM ----------
hope this pic is better wonder if my make shift tank is to high
I was thinking maybe my tank was not low enouf that this could coz the drainage
Alpha DeLaval tjohnson Hit & Miss Gas Engine Discussion 2 07-10-2010 02:19:10 PM
Alpha DeLaval Nick Hit & Miss Gas Engine Discussion 4 10-21-2008 09:58:12 AM
Alpha Delaval Help Joe Hugh Hit & Miss Gas Engine Discussion 1 01-23-2008 10:36:46 PM
Alpha DeLaval dougtorry Hit & Miss Gas Engine Discussion 0 01-22-2008 11:20:40 AM
I did it! (Alpha DeLaval) Greg-N-CA Hit & Miss Gas Engine Discussion 4 10-05-2007 02:10:08 AM
