Jacobson Machine Mfg. Co., Warren, Pennsylvania
this thread has 396 replies and has been viewed 77531 times
Old 12-23-2013, 08:57:16 PM
Don Worley Don Worley is offline
Default Re: Jacobson Machine Mfg. Co., Warren Pa.
Home-made use for a Jacobson.
Old 12-24-2013, 08:31:05 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is online now
On page 20 of Montgomery Ward's "Bull's Eye" engine catalog they show this "Competitor" gasoline engine which is shipped directly from the factory in Iowa. This one is no Jacobson. Who built it?
Denis Rouleau
The Following User Says Thank You to Denis Rouleau For This Post:
  #123
Old 12-24-2013, 10:16:46 AM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Finally got around to digging my Jacobson out to get pictures of it. I sent info to Denis for addition to the registry. This has been a very informative thread. Thanks to all.
ID:	182835   Click image for larger version
ID:	182836   Click image for larger version
ID:	182837   Click image for larger version
The Following 6 Users Say Thank You to Dwayne Fuller For This Post:
  #124
Old 12-24-2013, 10:07:22 PM
My 2 hp Jacobson. ser. no. 7136 vertical gov.
The Following User Says Thank You to Don Worley For This Post:
  #125
Old 12-24-2013, 10:16:41 PM
Another picture of the factory. Too bad it wasn't a little more to the right. There is an oil well there. Can't see what kind of engine is there.
  #126
Old 12-25-2013, 11:04:28 AM
Here is the index web page to all the Jacobson Machine Mfg. Co. pages I have put together so far with your help, including the Jacobson registry: http://buzzcoil.brinkster.net/moody/000index.html
Together we can find more stuff and add to what we already have. Thank you and have a Merry Christmas!
Denis Rouleau
The Following 4 Users Say Thank You to Denis Rouleau For This Post:
  #127
Old 12-25-2013, 11:56:07 AM
7 HP Maynard s.n. 10343
If you need Jacobson information or parts feel free to contact me.
worley@westpa.net
Lets keep the thread going.
Also, keep sending your information to Denis.
I believe that there are at least 500 maybe even 1000 Jacobsons out there.
Name:	7 hp maynard.JPG
ID:	182963   Click image for larger version
Name:	tag 7 hp maynard.JPG
The Following 3 Users Say Thank You to Don Worley For This Post:
  #128
Old 12-25-2013, 11:35:10 PM
Denis; I think that the engine registry has done quite well. It has been a little over a month and many engines have been added-a lot with pictures.
Everybody with a Jacobson made engine please send in the information. Don't feel that you must send a picture. A picture is nice but the serial number and other info is important for the registry.
Thank you for your work Denis!
Old 12-26-2013, 09:55:15 AM
Hi Don, you have been of great help too for someone who hates to type and used to be computer shy. For me it is not work, or if it is work, it is work I like to do.
Prior to starting this thread on Jacobson and after checking for prior post on SmokStak I was surprised to see that there was almost nothing about the Jacobson Machine Mfg. Co. of Warren Pa.
We have gathered a lot about Jacobson in a short time and I'm sure that with your help, much more info can be gathered and shared with everyone.
Don, you are correct, info about a Jacobson can be added to the registry even if pictures are not available at this moment. Pictures can always be added later when they become available.
Everyone, don't be shy and send in anything you have about Jacobson and Jacobson built engines and related literature and old advertisements.
Denis Rouleau email: buzzcoil2@videotron.ca
Old 12-26-2013, 01:04:52 PM
Yes, Jacobson even made a 2 hp tank-less. Sn 7888
The Following 2 Users Say Thank You to Don Worley For This Post:
  #131
Old 12-26-2013, 01:45:21 PM
Jeff Wahl's Avatar
Jeff Wahl Jeff Wahl is offline
This is the nicest color illustration I've seen of the Bull's Eye engines. I believe this illustration comes from a Montgomery Ward catalog, but not sure where I "borrowed" this photo from?
-Jeff
wahlengines.com
The Following 9 Users Say Thank You to Jeff Wahl For This Post:
  #132
Old 12-26-2013, 05:12:45 PM
Doug Sather Doug Sather is offline
Jeff: Great picture
The Following User Says Thank You to Doug Sather For This Post:
  #133
Old 12-26-2013, 05:55:35 PM
Here is a Titusville engine that uses the model U cylinder and was factory made into a sideshaft. 2 1/2 hp ser no 18008. The valves are accessed through the water hopper. if it weren't a sidshaft it would be a Unito. Probably made 1924. Now my engine.
ID:	183090   Click image for larger version
The Following 5 Users Say Thank You to Don Worley For This Post:
  #134
Old 12-26-2013, 05:57:42 PM
Jeff;
Never saw one like it. Great!
  #135
Old 12-26-2013, 06:18:38 PM
Here is a Titusville engine that uses the model U cylinder and was factory made into a side shaft. 2 1/2 hp serial no 18008. The valves are accessed through the water hopper. if it weren't a side shaft it would be a Unito. Probably made 1924. Now my engine.
I doubt there is another one just like it. Jacobson probably only built 2 or 3 like this to start with. When you say now my engine. is the "now" like "today"?
Denis Rouleau
Old 12-26-2013, 07:39:53 PM
Don: Like those Titusville engines
Old 12-26-2013, 11:40:47 PM
Denis; I got it this week.
Old 12-27-2013, 09:58:20 AM
Jeff Wahl's Avatar
Here are some pictures of our 5 HP Jacobson to add to the registry. It is a Titusville, PA engine with serial #19057. In the last picture, you can see the original cast cylinder plate with 4 pedestals. Not sure what was originally mounted on top of this? You can also see a groove in the inner hub of the off side flywheel for running a belt to theoretically whatever was mounted on top of the cylinder. We've had this Jacobson running nicely, and plan to give it a new paint job one of these days. It would not look the way it does today without Don's help! Many thanks!
-Jeff
wahlengines.com
The Following 3 Users Say Thank You to Jeff Wahl For This Post:
  #139
Old 12-27-2013, 10:01:54 AM
This is one of the best sheets I have seen for headless. 1907
Old 12-27-2013, 10:05:41 AM
Jeff,
Maybe there was a mechanical lubricator mounted on top of the cylinder.
Machine shop in western Pennsylvania? J. Sutter Antique Gas Engine Discussion 3 09-25-2014 09:33:33 PM
THe Little Elgin-RA warren Tom Hartfield Small Air Cooled Gasoline Engines 1 03-05-2012 05:31:18 PM
Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES) Denis Rouleau Antique Gas Engine Discussion 10 06-18-2011 11:15:59 PM
WD-40 IH at J.B. Warren Sale Eric Best Antique Farm Tractors 0 09-23-2005 09:35:45 PM
