Ignorance relief
this thread has 7 replies and has been viewed 1402 times
Old 02-04-2016, 01:34:17 PM
Dwayne Oxford Dwayne Oxford is offline
Default Ignorance relief
The red handled tool has no marking.
The castings are 8-19-80 or 08-61-8. They're out of a friends shop who had a small engine business, sadly now has alzheimers.
Old 02-04-2016, 01:38:36 PM
Default Re: Ignorance relief
Sorry, forgot pics.
ID:	245577   Click image for larger version
ID:	245578   Click image for larger version
ID:	245579   Click image for larger version
The Following User Says Thank You to Dwayne Oxford For This Post:
Old 02-04-2016, 04:45:43 PM
tdmidget tdmidget is offline
The second one appears to be a flywheel puller. The ist one might be a ring compressor but need something there for scale.
The Following User Says Thank You to tdmidget For This Post:
Old 02-05-2016, 03:32:29 PM
Hope this pic helps.
Also, one casting is bored 2", the other threaded 1 5/8' x 18, holes are on 3" circle
Old 02-06-2016, 04:24:22 PM
Nickel City fab Nickel City fab is offline
Looks a LOT like clutch hub tools for eg bike clutches or chainsaws etc.... very often the older japanese engines had a threaded clutch hub, you would use a bushing that was threaded both inside and out, with a spindle and handle... hold the handle with one hand, turn the spindle with the other till it pops off the end of the crank.
The Following User Says Thank You to Nickel City fab For This Post:
Old 02-06-2016, 04:46:10 PM
Thanx, he was a Hodaka dealer. Good place to start.
Old 02-06-2016, 08:46:59 PM
ronm ronm is offline
It's a $100 Penny Pincher!
Old 02-06-2016, 09:02:30 PM
Contaucreek's Avatar
Contaucreek Contaucreek is offline
Hodaka!!
Relief valve question UpinSmoke Live Auctions of Engines, Tractors and Old Iron 1 09-19-2014 07:43:47 PM
Lombardini ignorance relief Dwayne Oxford Vintage Diesel and Oil Stationary Engines 3 12-18-2011 07:21:32 PM
Oiler blow by relief R. Kern Hit & Miss Gas Engine Discussion 9 05-29-2008 02:36:42 PM
