Split Case Pillow Block Bearings - Disassembly?
this thread has 7 replies and has been viewed 918 times
Old 02-05-2016, 10:54:48 PM
Default Split Case Pillow Block Bearings - Disassembly?
Anyone know anything about split case pillow block bearings? I'm looking at a set of 6+" diameter pillow block bearings and need to see about getting the shaft between them out. Is the bearing split also? Or do you split the cases and then have to press bearings off the shaft? I'm hoping the bearings split.......
Old 02-06-2016, 09:07:28 AM
Rob Charles Rob Charles is offline
Card Sponsor
Default Re: Split Case Pillow Block Bearings - Disassembly?
The ones I worked on were in the 4 1/2" range. The cases were split and the bearings were not. The idea is you press the bearings onto the shaft and then drop the assembly down into the housings. Sorry it's not what you want to hear. Rob
The Following User Says Thank You to Rob Charles For This Post:
Old 02-06-2016, 10:22:13 AM
Pauls Welding Minnesota Pauls Welding Minnesota is offline
Take the cap off one of them to have a look, you might get lucky and it will be the bearing with a tapered sleeve that pulls into the bearing id with a big nut with the tang washer behind it. Bend lock tangs up hammer and punch in notches to loosen nut then drive sleeve back until it releases.
The Following User Says Thank You to Pauls Welding Minnesota For This Post:
Old 02-06-2016, 11:06:53 AM
tdmidget tdmidget is offline
It sounds like it might be spherical roller bearings. If you are after the pillow blocks and bearings then there is a procedure to install. You must find from the manufacturer a spec on the clearance reduction. You measure the clearance and force it up the taper until you achieve the required reduction. It will probably have a tapered sleeve but the taper can machined with shaft.
---------- Post added at 08:06:53 AM ---------- Previous post was at 08:02:20 AM ----------
I posted before I intended to. To remove them you remove the locking nut. There should be a grease fitting somewhere on the large side of the taper or a hole to put one in. With a hand grease gun pump until the bearing pops off. Be careful, it can be pretty violent and a bearing that size can hurt.
Does this board have an edit function?
The Following User Says Thank You to tdmidget For This Post:
Old 02-06-2016, 06:33:07 PM
Thanks guys! Pulled the bearings this morning, fortunately I did not have to worry about pulling the shaft, turns out its just 6" tubing and thin wall stuff, so not enough weight to worry about. One of the local mfr's makes all sorts of crazy test jigs with expensive parts, then scraps them. These are monster bearings, tipped the scale at just under 600 lbs for the pair
ID:	245710   Click image for larger version
ID:	245711   Click image for larger version
Old 02-06-2016, 10:54:34 PM
Those are known as BMF bearings. Should be worth a few bucks.
Old 02-07-2016, 12:04:48 AM
Had to look these up because somehow I've never heard of Craft bearings. Need to look at them again Monday, but it looks like these are a split case, split bearing design, made in America, and pretty pricey.
http://www.craftbearing.com/
Old 02-07-2016, 12:10:56 AM
You scored. Hope you can peddle them at a good price.
Case 15-27 rear axle bearings Airtractor76 Antique Farm Tractors 3 08-28-2015 11:18:49 AM
Jumbo, main bearings? Shell or in block? agusta74 Hit & Miss Gas Engine Discussion 4 08-05-2012 06:43:47 PM
Split rim Question? Adam Hartz Antique Autos and Trucks 18 03-16-2011 10:26:33 PM
Making Split Bearings alext Machine Shop and Tool Talk 2 06-01-2009 02:53:38 AM
Pillow Block Bearings d.j.baisch Antique Engine Archives 9 12-26-2002 05:31:22 AM
