Inexpensive Crankshaft Polisher
this thread has 0 replies and has been viewed 2911 times
Old 01-07-2016, 11:57:13 AM
Jim Parrott Jim Parrott is offline
Default Inexpensive Crankshaft Polisher
Crankshaft Polisher from HF Sander
I was lucky enough to purchase a production crankshaft polisher off craigslist for a reasonable price. My friend JB Castagnos had purchased a crankshaft grinder some time back and was in need of a polisher. I decided to build him one using mine for a guide.
I purchased a Harbor Freight 60543 1" X 30" Belt Sander, removed the base plate, table, and covers. Cut out the mid section along drawn lines, leaving the top and bottom radius for strength. Bent a piece of square aluminum tubing 3/4" OD X .125" X 5', and attached it to the motor side of sander frame for alignment and strength. Attached a piece of 1" steel square tubing with 1/4 nuts welded on for adjusting knobs to top roller section with countersunk screws. The steel tubing overlaps the side of the top roller section to compensate for alignment with base. The handlebar is simply bent 1/2" conduit clamped in a micarta block that was drilled and cut in half. Hardwood or aluminum could also be used and the angle is adjusted for balance. Assembled, the rollers are a little offset from centerline, this is how my factory built polisher is also.
I am really happy with how it works and was built on a very small budget in a short time.
JB Finishing a Fairbanks piston pin with polisher.
https://www.youtube.com/watch?v=Z36b...m-upload_owner
Jim
ID:	243171   Click image for larger version
ID:	243172   Click image for larger version
ID:	243173   Click image for larger version
Best inexpensive oscilloscope Bassplayer1985 Generators & Electric Motors General Discussion 35 03-12-2015 12:25:18 PM
Inexpensive(?) Diesel Recommendations Graycenphil Generators & Electric Motors General Discussion 32 10-04-2011 06:20:52 AM
(relatively) Inexpensive electronic governor? Wayne 440 Generators & Electric Motors General Discussion 18 10-15-2009 08:09:06 PM
I'm looking for an inexpensive hit and miss Dallies Wrenn Hit & Miss Gas Engine Discussion 6 10-15-2009 08:59:58 AM
Inexpensive oilers Norbert Arnold Antique Engine Archives 0 12-08-2003 11:55:37 AM
