gear making
this thread has 3 replies and has been viewed 1114 times
Old 01-29-2016, 09:40:56 PM
Nebraska Kirk Nebraska Kirk is offline
Default gear making
I got everything set up and made some gears this week, #10 pitch and 14 teeth. They are replacements for an old sheet metal "slip roll"
https://youtu.be/TtoD-evUw3I
https://youtu.be/56gmgf4v3Lo
ID:	245040   Click image for larger version
ID:	245041   Click image for larger version
The Following 13 Users Say Thank You to Nebraska Kirk For This Post:
Old 01-29-2016, 10:16:28 PM
Default Re: gear making
That's some serious setup work. Well done.
*likely required a couple beers.
Old 01-30-2016, 06:41:49 PM
Card Sponsor
What make dividing head is that? I see it's a power head.I always wondered how much trouble it would be to make the plates ,shafts,gears,etc to run a power head on a Bport. First problem is the table on a Bport has a 5 threads per inch screw and most horizontal mills have a 4 tpi screw. Just a bunch of calculations I suppose. Rob
Old 01-30-2016, 07:49:07 PM
That dividing head was made in Japan, it says Tsudqkoma on it.
Frick 9.5x10 drive gear and pinion gear mash6469 Steam Stationary Engines, Traction Engines 2 04-18-2010 02:08:08 PM
New Gear Source: Martin Gear + Sprocket PaulGray Hit & Miss Gas Engine Discussion 3 01-22-2008 09:54:45 AM
Sattley cam gear and crank gear timing Judson Hit & Miss Gas Engine Discussion 2 11-18-2007 07:21:11 PM
Making Valves Dean Alling Antique Engine Archives 6 08-02-2004 05:15:38 PM
Making it all better Fairbanks_Kid Antique Engine Archives 9 05-03-2001 07:54:15 PM
