Steam Engines
Hancock Inspirators
this thread has 2 replies and has been viewed 2670 times
Old 10-18-2011, 08:03:26 PM
Jim Mackessy Jim Mackessy is offline
Default Hancock Inspirators
Has anybody here used "Hancock Inspirator" type injectors? I was wondering what adjustments are typically made and why, once the initial instructions have been followed and the injector is started. Also, since the overflow is positively shut off, how does one know when the injector "breaks", or isn't this a worry with this type? Thanks in advance;
Jim Mackessy
Old 10-18-2011, 11:20:57 PM
David's Avatar
David David is offline
Default Re: Hancock Inspirators
The family had a new 1/2" Fairbanks inspirator (identical to the Hancock) that had been around a long time before I was born, so when I got my 6 h.p. Geiser portable, I put it on, since my grandfather had used inspirators in the old days and knew how to start one
They work at a lower pressure than an injector (the Fairbanks will still work just below 10 psi), but when it kicks off, all the valves must be shut or opened to restart it.
When it kicks off, live steam blows through the inspirator back into the makeup water.
They are interesting, and I'm glad to have it on the Geiser. One can readily see why they were quickly replaced by Penberthy, American, U.S., and other makes of injectors.
I have a cut somewhere about inspirators and how they work, and I'll scan it as soon as I find it.
David
The Following 2 Users Say Thank You to David For This Post:
Old 10-19-2011, 08:38:43 AM
David's Avatar
A cut from a 1925 catalog.
It is interesting to note that an inspirator will pump hot water, whereas injectors like the standard Penberthy (00,AA, BB, etc.) will not.
David
The Following 7 Users Say Thank You to David For This Post:
Hancock Shaker Village Fair and Show Ed Kuni Hit & Miss Gas Engine Discussion 0 09-14-2008 08:07:39 PM
2" Hancock Inspirator Harvey Teal Steam Stationary Engines, Traction Engines 2 04-02-2008 12:11:08 PM
Engine auction at Hancock, Maryland HBurk Live Auctions of Engines, Tractors and Old Iron 3 09-30-2006 10:19:38 PM
Looking for Dave Hancock Rich Martz Hit & Miss Gas Engine Discussion 0 05-24-2006 07:16:58 PM
hancock injectors Andrew Steam Stationary Engines, Traction Engines 0 04-16-2003 10:43:39 PM
