My WMB quit me?
this thread has 13 replies and has been viewed 2069 times
Old 02-08-2011, 07:21:44 PM
doggbiter doggbiter is offline
Default My WMB quit me?
My wmb up and quit me, pulled plug and ground to block and it shows good spark. It won't even hit on ether, any ideas?
http://http://www.youtube.com/watch?...er_profilepage
This was before the mystery failure, just won't hit overnight.
Old 02-08-2011, 07:28:57 PM
Canadian made Canadian made is offline
Default Re: My WMB quit me?
Maybe a broken flywheel key? That would make it fire at the wrong time.
The Following User Says Thank You to Canadian made For This Post:
Old 02-08-2011, 07:29:06 PM
http://www.youtube.com/watch?feature...&v=s0Ms5BBk-XQ
Old 02-08-2011, 08:54:39 PM
D Behnke D Behnke is offline
This may sound strange, but have you tried replacing the spark plug?
The Following User Says Thank You to D Behnke For This Post:
Old 02-09-2011, 04:57:09 PM
BHartley BHartley is offline
Does it have compression? (stuck valve?) I have had even brand new spark plugs be bad. Try swapping in a plug you already have from another working motor. Broken flywheel key idea is a good bet, too. Be sure and post the fix when you figure it out. Bruce
Old 02-09-2011, 09:11:03 PM
makoman1860 makoman1860 is offline
Sheared key would cause loss of spark, not wrong timing. Look somewhere else. If it feels like it has compression, its a fuel related issue.
Old 02-09-2011, 09:27:15 PM
Junkologist's Avatar
You can definitely shear a key and still have spark. Been down that road before. When they're like that, they'll rip the starter rope right out of your hand, and boy does that sting sometimes!
Mike
SmokStak member #146
Old 02-09-2011, 10:20:48 PM
Old Horse Old Horse is offline
sting is an understatment.
Old 02-10-2011, 01:25:48 AM
Not on a points system, point opening controls ignition time, not the magnets position as with the later systems. If you shear a key on a points mag all it will do is either weaken spark or kill it all together.
The Following User Says Thank You to makoman1860 For This Post:
Old 02-10-2011, 06:09:21 PM
K D Redd K D Redd is offline
makoman1860 IS RIGHT. Sheared key will kill the spark. Points and magnets are out of time. It is ONLY the later MAGNETRON and other electronic triggered magneto that will have fire but the fire will be out of time with the piston.
Kent
Old 02-12-2011, 07:45:50 PM
Thanks for the responses, it has good compression. Can anyone tell me the correct spark plug to use, I beleive it had a champion CJ 6 Y in it when I got it. I put a cj8 in it and it worked with that for awhile, until the day it just would not fire.
So please if anyone knows the correct spark-plug, please clue me in!
Old 02-13-2011, 01:12:06 PM
Johnnyboy Johnnyboy is offline
I have been using the NGK B2-LM and this ia also the plug that you can remove the piece on the top of the plug to attach loop type plug wire and they have worked just fine for me.
Old 02-13-2011, 01:48:52 PM
James Bosma's Avatar
James Bosma James Bosma is offline
Have you checked the fuel system. Check ball could be stuck and not allowing gas to get to motor. I usually have a 1 or 2 i have to free up in spring on my Iron-Horse or Brigg engines that i have.
Old 02-13-2011, 10:56:52 PM
http://http://www.youtube.com/watch?...etailpage#t=4s
Just needed a new plug......fired right up and won't quit! Thanks to everyone on here!
---------- Post added at 09:56 PM ---------- Previous post was at 09:53 PM ----------
http://http://www.youtube.com/watch?...yer_detailpage
Can't quit buying these $%^& things... Wayne 440 Onan Generators 9 06-28-2010 09:49:40 PM
LowBoy just quit - no spark flockshot Garden Tractors and Mowers 10 05-11-2010 10:43:26 AM
Homelite 116 A 50-2L Quit Working Jim Tremble Generators & Electric Motors General Discussion 6 04-08-2009 11:52:26 AM
When did NOVO quit ? David M. Lyon Antique Engine Archives 1 06-06-2003 12:39:44 PM
