6.5 NHD quit generating
this thread has 1 replies and has been viewed 1733 times
Old 08-13-2011, 11:45:55 AM
ispliceworld ispliceworld is offline
Default 6.5 NHD quit generating
Hi - all
First off I have a ONAN 6.5NHDFB30502M Serial # D0000 89093
The problem started when I went to start the generator after sitting a while, the battery was low but gen started up and ran perfect - appeared to be no output voltage, after futher checking, output voltage was 48 volts at 62 hz, brushes are new, changed out voltage regulator (I have a spare) same thing not enough output.This is the first problem, now on to the second or most recent problem, with the circuit cover off checking votages etc, The L0 J3 and the L1 J4 came unplugged while it was running when these wires came unplugged it engaged the starter - need to know where these wires go, they come out of the control board and go somewhere on the output side of the generator- where my breakers etc are. I have cleaned the slip rings 7 ohms reading across slip rings, nothing to ground , I read 2.7 k ohms reading across brushes with them out of gen With wires still attached. Any help would be greatly appreciated. Taking it to a cummins mechanic wil be kinda of a hassle as they are about 50 miles away, if any one has a wiring diagram for this genset would be very helpful- Thanks again
Old 08-13-2011, 02:47:32 PM
Flintstone Flintstone is offline
Default Re: 6.5 NHD quit generating
On my very different unit, one AC ring (the neutral ), is grounded.(through the brush) One prong of a plug, 1/2 the DC brushes, 1/2 the AC brushes, all grounded. This is a comment to THINK on. You'd be better off to get advice from "a resident smart guy", before ACTING. (on that). D.
My WMB quit me? doggbiter Small Air Cooled Gasoline Engines 13 02-13-2011 10:56:52 PM
Onan 30.ODDA-9XR/1468D - Quit generating AC Geraldlodge Onan Generators 2 12-14-2010 09:58:47 PM
LowBoy just quit - no spark flockshot Garden Tractors and Mowers 10 05-11-2010 10:43:26 AM
Homelite 116 A 50-2L Quit Working Jim Tremble Generators & Electric Motors General Discussion 6 04-08-2009 11:52:26 AM
When did NOVO quit ? David M. Lyon Antique Engine Archives 1 06-06-2003 12:39:44 PM
