Clinton VS 300
this thread has 5 replies and has been viewed 360 times
Old 10-03-2019, 08:17:28 PM
pigpen60 pigpen60 is offline
Default Clinton VS 300
I picked up a Clinton VS 300 today and I'm looking for when it was built and anything else you can tell me about it.
I cannot read the tag except for 2026375 D VS300KOF
ID:	345643   Click image for larger version
ID:	345644   Click image for larger version
ID:	345645   Click image for larger version
ID:	345646   Click image for larger version
The Following 2 Users Say Thank You to pigpen60 For This Post:
Old 10-03-2019, 11:49:47 PM
ulgydog56's Avatar
Default Re: Clinton VS 300
sweet looking engine....
Old 10-04-2019, 12:01:36 AM
K-Tron K-Tron is offline
Your VS300NOF was originally used on a Huffman Mower. It was rated 1.4hp @ 3600rpm with a 2" bore and 1-1/2" stroke. 4.72 cubic inch displacement. That is a nice find. You do not see too many of the smaller vertical shaft Clinton's these days. I believe the Schnacke recoil on yours was added on later. I have only seen these engines with a wrap-a-rope starting cup before. It appears as if your engine is only missing the gas tank. That should not be too hard to located. It is likely the same size as most other Clinton and Lauson engines of that time frame.
Chris
The Following 2 Users Say Thank You to K-Tron For This Post:
Old 10-04-2019, 11:08:26 AM
Thanks for the replies, I saw it and thought it was a cool little engine. Impulse buy!
Old 10-04-2019, 11:27:18 AM
Can anyone tell me what oil to use with this engine? 30wt like everything else?
Old 10-04-2019, 11:40:51 AM
JFLingg's Avatar
JFLingg JFLingg is offline
Default Huffman Mower - VS 300 Clinton, Instruction Sheet
Around 1953, as a teenager, I owned and used one of these mowers. I often had trouble starting it, maybe I wasn't wise to them. With the rope cup as a pulley, I used a long V-belt and an electric motor to start it. I remember cleaning the metal mesh air filter on a very regular basis. Four little swinging blades on a disk for the blade, would not throw anything that way.
JFLingg
PS: Instruction sheet says it's a VS-2100???
ID:	345684   Click image for larger version
The Following 2 Users Say Thank You to JFLingg For This Post:
Clinton VS 800 stutrac Garden Tractors and Mowers 1 08-05-2014 04:09:16 PM
What Clinton Do I Have? engineAdam Small Air Cooled Gasoline Engines 3 07-18-2013 08:04:54 PM
Need help on Clinton I.D. thefox48 Garden Tractors and Mowers 3 10-26-2011 05:28:25 AM
Little Clinton 100 KidDynamo Small Air Cooled Gasoline Engines 4 12-16-2010 11:41:06 PM
clinton Kyle McGee Small Air Cooled Gasoline Engines 2 08-09-2005 11:59:00 AM
