Wisconsin Engines
Wisconsin THD air filter question
this thread has 4 replies and has been viewed 3267 times
Old 02-11-2006, 10:19:30 PM
albngore albngore is offline
Default Wisconsin THD air filter question
My THD has an oil-bath air filter. The top of the filter is just an open tube, maybe 1.24 inches in diameter and approx. 3" long. Is anything supposed to be on top of this tube? Or, inside this tube? Didn't look right to me so I have always clamped an old sock on it to keep out large debris. But, I got curious as I would like to keep this great old engine running for many more years.
Also, is there a replacement dry-type air filter available to use instead of the oil bath? If so, where might I be able to buy one? Thank you, Brad.
Old 02-11-2006, 11:20:24 PM
MoRo's Avatar
MoRo MoRo is offline
Default Re: Wisconsin THD air filter question
I believe there should be some sort of cover. It would sit above the tube to allow air to pass through into the oil bath.
Old 02-12-2006, 01:09:23 AM
Brad,
Here's what the components for the air cleaner for your engine should look like, depending which type you have.
Bill
Name:	Wisconsin THD air cleaner.jpg
Old 02-12-2006, 01:17:56 AM
Bill, that blowup sure helped me see what is missing. Thank you so much. Might you know where I could either buy an entire air cleaner, or where I could get part numbers: 159A, 159B, and 159D? Thanks again. Brad
Old 02-12-2006, 10:50:52 AM
Try a wisconson dealer - they are probably in stock! Check Harry's advertisers as well.
Andrew
Onan MEP 016B Military Fuel Filter & Air Filter (Help) Doogdoog Onan Generators 12 08-17-2015 07:38:11 PM
Wisconsin info timing and oil filter PMilten Wisconsin Engines 2 03-10-2008 11:00:06 AM
Wisconsin BKN oil bath air filter meduffer Antique Gas Engine Discussion 2 11-04-2007 08:55:18 AM
Question on Wisconsin AEH. Will Batty Wisconsin Engines 2 01-08-2007 12:53:52 AM
Wisconsin Question? JKWidener Wisconsin Engines 1 10-17-2006 07:40:53 PM
