Wisconsin Engines
Wisconsin gear box
this thread has 3 replies and has been viewed 2284 times
Old 06-07-2006, 07:22:55 PM
DRoberson51 DRoberson51 is offline
Default Wisconsin gear box
I have a wisconsin agnd with a clutch and gear box on it. Does anyone know what weight oil to put in the gear box. Thanks , Dennis
Old 06-07-2006, 08:05:04 PM
Zira Zira is offline
Default Re: wisconsin gear box
Manual says SAE 30
Old 06-07-2006, 08:41:23 PM
Dustin D Ehli Dustin D Ehli is offline
Images: 15
Zira i beleive you are correct but to be more correct some of the manuals i have say to use whatever weight oil you have in the engine in the gearbox.
This may only come into real concern in very hot or cold conditions.
Dustin
Old 06-09-2006, 06:56:32 AM
Thanks for the info
Wisconsin Cam Gear Bernie Brown Wisconsin Engines 0 02-02-2008 10:03:05 AM
New Gear Source: Martin Gear + Sprocket PaulGray Antique Gas Engine Discussion 3 01-22-2008 09:54:45 AM
Sattley cam gear and crank gear timing Judson Antique Gas Engine Discussion 2 11-18-2007 07:21:11 PM
Wisconsin timing gear Dianna Wisconsin Engines 2 08-24-2005 11:59:29 AM
GEAR WTD A.J. TELOWICZ Antique Engine Archives 1 02-11-2003 11:07:13 PM
