Wisconsin Engines
Schramm compressor with Wisconsin engine
this thread has 4 replies and has been viewed 5386 times
Old 05-08-2005, 02:41:52 PM
junkyard4$ junkyard4$ is offline
Default Schramm compressor with Wisconsin engine
I have a Schramm model 35 compressor that is based on a Wisconsin V4 engine. Runs on 2 and compresses on 2. The engine side has a stuck valve which I am freeing now but I need to know what model Wisconsin engine Schramm used so I know what head gasket to get. It would also be helpful if I ever need any more parts in the future. Does anyone have any info on these?
Thanks,
Paul
Old 05-08-2005, 05:53:26 PM
Zira Zira is offline
Default Re: Schramm compressor with Wisconsin engine
Paul -
They used several, most commonly the VG4. If you have the head off the engine side, tell me the casting number & I can probably tell you which model motor it is.
Old 05-08-2005, 06:21:22 PM
Zira,
The casting number on the head is very light and hard to read but the best I can come up with is AB-91-D, the number on the block is BA-49A. The engine has a 3.5" bore and a 4" stroke. Any info would be great.
Thanks,
Paul
Old 05-09-2005, 05:55:41 PM
Same as I told Paul, the VG4 seemed to be the favorite but if you give me the casting number off the head (motor side, not compressor side) I can probably tell you for sure. This is located on the gasket surface, but it sounds like you have the head off anyway.
Old 05-09-2005, 06:05:27 PM
Zira,
In my last post I gave you the casting number that was on the head of the engine side. It is AB-91-D. At least that is the best I can read it to be, it is a very lightly cast number.
Paul
Schramm Tractor Air Compressor 35 thomas whitley Antique Gas Engine Discussion 11 09-02-2018 05:14:13 PM
Schramm Air Compressor Andrew Mackey Antique Gas Engine Discussion 3 05-03-2009 09:20:48 PM
Schramm engine-air compressor Andrew Mackey Antique Gas Engine Discussion 14 09-03-2007 04:27:37 PM
Schramm Domestic Compressor Joe Prindle Antique Engine Archives 0 06-17-2003 01:21:15 AM
Schramm air compressor DANIEL DORECE Antique Engine Archives 1 04-15-2003 11:30:52 PM
