Wisconsin Engines
wtb carb for wisconsin s14d
this thread has 17 replies and has been viewed 9550 times
Old 10-31-2005, 09:17:48 PM
indmachrep indmachrep is offline
Default wtb carb for wisconsin s14d
i am looking for a carb for a wisconsin s14d it has a zenith carb #13385 i believe the zenith number is 1408. i will take any part of the carb i can find. please email me if you have info at asp3211968@aol.com
Old 11-01-2005, 10:30:36 AM
Bill Rogers Bill Rogers is offline
Default Re: wtb carb for wisconsin s14d
Hello;
I have a good complete Zenith carburetor off from a Wisconsin AEN, 23 cubic inch engine. The numbers on the carburetor are; 12334D and a pooly stamped number of 63B.
I don't know if this can help you as I do not know what your carburetor looks like. I do also have the intake manifold and the big oil bath air filter.
Please advise if this will help.
Regards;
Bill Rogers
Old 11-01-2005, 12:02:29 PM
bill thanks for aresponce. there is a little problem with most other carbs. the one that i have has the mounting flange set at a 45 degree angle. your carb will probably have them mounted horizontally. also is it a side draft carb.
Old 11-01-2005, 07:22:17 PM
ldj1002 ldj1002 is offline
I have a s8d and a s12d and neither have a carb. with 45* bolt pattern for the carb. Both engines look just alike. I thought that s14d was just like the other s__d engines. Do you reckon either both mine or yours has the wrong air shroud and that isn't what the engine really is? Or is the manifold bolt pattern actually different on the s14d from the others in that series?
L.D.
Old 11-02-2005, 11:42:03 AM
i notice on the s12d that they have the head and an elbow that connects to a downdraft carb. on the eng the studs sit horizontal. on my engine i have a sidedraft carb and the studs sit at a 45 degree angle. this is correct according to parts manual. unfortunatly i have a good engine that was set up for propane and the idle tube that sits in the card throat was broken. i have not been able to find this part or a carb. the unit is still good for propane use. this is a 7kva generator
Old 11-02-2005, 02:20:08 PM
Judging from illustrations that I have, I would guess the carburetors for the S-10D, S-12D and S-14D are the same or similar. The S-8D uses an updraft carb with a right angle manifold that bolts to the side of the cylinder.
The S-10D and S-12D engines use a horizontal Zenith model 1408 carburetor, Wisconsin Motor No. L-86 Series according to my Wisconsin manual for the S-10D & S-12D models.
Bill
Old 11-02-2005, 02:38:11 PM
Here's a couple of scans showing carbs on S-10D, S-12D and S-14D Wisconsin gasoline engines. Maybe the carb set up was different for propane?
Bill
Name:	Wisconsin S-10D, S-12D.jpg
ID:	4772   Click image for larger version
Name:	Wisconsin S-14D.jpg
Old 11-02-2005, 03:37:36 PM
this is a list of carbs for the s-10,12,14-d wisconsin if you notice the zenith numbers indacate ther is 2 different body styles l86 and l95 i need an l95. i am contimplating making an adapter plate and connecting the l86. what do you guys think
CARB. REF. NO. ZENITH ASSEMBLY NO. WISCONSIN PART NO.
1 13022-B L-86-A-S1
2 13027-B L-86-6-S1
3 13040-B L-86-C-S1
4 13064-A L-86-D-S1
5 13137-A L-86-E-S1
6 13138-A L-86-F-S1
7 13155-A L-86-G-S1
8 13208-A L-86-H-S1
9 13224-A L-86-J-S1
10 13225-A L-86-K-S1
11 13187-A L-86-L-S1
12 13188-A L-86-M-S1
13 13322-A L-86-Q-S1
20 13385-A L-95-S1
21 13417-A L-95-A-S1
22 13395-A L-95-B-S1
23 13561-A L-95-C-S1
25 13557-A L-95-E-S1
26 13573-A L-95-F-S1
28 13648-A L-95-H-S1
NOTE: Parts are identical for all carburetors, except those identified by carburetor Ref. No.
Old 11-02-2005, 03:54:50 PM
http://www.jacques.lacasse.com/Garde...D/Page9-10.htm
the second picture shows a carb that sits on a 45 degree angle this is from the manual for wisconsin. let me know if the linl works
Old 11-02-2005, 04:17:09 PM
My engines aren't like that. Even the air shrouds are different including where the logos and model #'s are. My air shroud clearly says s12d and s8d and those shrouds wouldn't fit the engine in your photos. What goes here?
L.D.
Old 11-02-2005, 04:31:58 PM
Link worked fine. Pretty hard to tell the carb mounts at a 45 degree angle from the illustration though. Don't see why an adapter plate wouldn't work as long as linkages hook up properly.
Bill
Old 11-02-2005, 04:46:27 PM
LD,
Does your S-8D look like the one below?
Bill
Old 11-02-2005, 07:36:59 PM
Bill,
That is the way it looks except mine has a side draft carb. My s12d looks the same.
L.D.
Old 11-02-2005, 09:22:34 PM
LD
Did you buy the S-8D new, or could someone have switched the carb before you aquired the engine? I checked a couple of different manuals and they both show the updraft carb on the S-8D.
Bill
Old 11-02-2005, 09:35:07 PM
Dan Peterson Dan Peterson is offline
The SD14 uses a L-95-S1 Carb. From looking in the book it is the same as the L-86 series except for the float valve, main jet and carb shaft. The L-86 might be eaisier to find and look for those other items one at a time.
Old 11-02-2005, 10:18:06 PM
Bill,
It came on a new auger made by a small manufacturing shop. I doubt they were a large enough place to have engines made to their specs. If the carb. has been changed it had linkage changed with it. The side draft carb. throttle shaft is a lot higher and the linkage has to make a big bend up then bend back to straight. It would be a little tricky for someone to have made that piece of linkage. Therefore it looks factory or at least from another engine where everything lined up just like this series.
L.D.
Old 11-02-2005, 10:33:28 PM
Maybe Wisconsin changed over the the updraft carbs to the the sidedraft carbs on later production engines? Might be some cost savings utilizing the same carbs as other engines in the S--D series.
Bill
Old 11-03-2005, 07:34:31 AM
s the side draft does anyone have the l-86 carb that is a side draft. any pic's. is there one for sale. there is no saving my carb, the part that was damaged is pressed in at the factory and not sold. my only choice seems to be finding a carb like mine or adapting a carb
Wisconsin ACN 400thacker Antique Gas Engine Discussion 6 01-31-2008 07:28:53 PM
S14d Wisconsin carconnection Wisconsin Engines 0 08-10-2006 06:03:21 PM
Wisconsin TJD s moore Garden Tractors / Mowers / Scooters 2 05-29-2006 08:22:43 PM
Need Wisconsin carb info. George Andreasen Antique Engine Archives 6 10-12-2003 10:09:42 PM
AEH Wisconsin Garry Antique Engine Archives 2 03-21-2001 07:43:50 PM
