Wisconsin Engines
Wisconsin no fire
this thread has 13 replies and has been viewed 2710 times
Old 12-31-2005, 12:41:13 AM
skartguy skartguy is offline
Default Re: Wisconsin no fire
Hello again just let you know if you go to an old school parts house you can still find regular resentiece wire in a role which old chrys. products used this will also work in place of a ballast res. hope it helps steve.
Old 12-31-2005, 04:15:48 AM
John Newman, Jr.'s Avatar
Mudcat,
In your original post you said:
"The engine generator does not work so I generally recharge the battery when it starts to cranks slower on start"
If you are having ignition problems on top of that, I would consider replacing the generator with a magneto. I believe it will fit the opening where the generator is without modification. I saw a 2-cylinder mag sell very recently on eBay for $15! This would eliminate the need for a battery, coil, resistors, etc. I have a good hot mag on my Wisc THD and it starts very easily with a rope.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 12-31-2005, 10:45:51 PM
Mudcat Mudcat is offline
Skartguy, are you talking about the fusible link wires?
I will be looking for a mag to sell on e-bay now. I have used this now for 2 days off and on and has worked flawlessly. I put a resistor from an old Chevy from the junkyard.
Thanks again guys.
Now I have an old Lister Petter diesel I need to get out and get it started.
Old 01-03-2006, 11:24:38 PM
Hello Again......there was also a restience wire that ran from coil to dist. on some models this way you could use a non rest. coil.....the wire looked alot thicker than an ordinary coil wire.....the fuseable link gose on the battey side of things.
Mega fire or Nova to fire Wico?? stugguls Magnetos, Ignition Coils and Spark Plugs 3 02-25-2008 10:25:59 PM
No fire on a 4.0bf-3cr biggerred Onan Generators 10 01-05-2008 09:34:37 PM
Banked fire ? Pete LaBelle Steam Stationary Engines, Traction Engines, Steam Boats 15 06-27-2007 12:21:39 AM
fire extinguishers Chan Mason Antique Engine Archives 9 05-22-2003 09:35:57 PM
What should I check before I fire it up? Norm Generators & Electric Motors General Discussion 3 03-07-2001 12:49:54 AM
