5hp Bovaird Seyfang Plumbing?
this thread has 4 replies and has been viewed 1132 times
Old 05-03-2018, 04:20:02 PM
George Best George Best is offline
Default 5hp Bovaird Seyfang Plumbing?
I've got a 5hp vertical BS with the hot tube.
I have questions on how to run this engine on propane.
Do I need a demand regulator on the fuel inlet?
I tried using 2 propane tanks. 1 tank for the torch using a bbq regulator.
1 tank for the fuel inlet. I have a demand regulator in line with the inlet.
Again this tank has a bbq style regulator.
We gave up without ever getting a pop out of the engine.
Any help or suggestions appreciated.
http://www.irontrader.com/
Old 05-03-2018, 09:23:55 PM
Tom Geier's Avatar
Tom Geier Tom Geier is offline
Images: 51
Default Re: 5hp Bovaird Seyfang Plumbing?
I get a regulator from a rv dealer or farm store.
Do i really look like a people person?
Old 05-04-2018, 04:57:33 PM
TomBall TomBall is offline
George, you should get something out of it with two different tanks and regulators. Is your hot tube getting hot enough? It is important to get it hot enough to fire on. I had a Myrick that gave me fits on a cool day till I lined the chimney. Then it ran. The tube would not get hot otherwise. That being said, is gas getting to you intake? I know it is a stupid question but weird stuff happens. Check the valve timing in case someone has had it apart before. Also, how long is the tube? Have you had this running before or did you recently get it?
Old 05-04-2018, 09:36:44 PM
I've had the engines around 10 years but never tried to run it until yesterday.
I am currently thinking that we didn't get the hot tube hot enough with the burner that came with the engine.
Compression isn't great on this engine but there is enough that if it was a spark fired engine it would run. Just don't know if compression is very critical with a hot tube or not.
Should the hot tube be heated enough to have a orange glow? It was hot when we pulled the chimney off to check it, but definitely not glowing or showing any color.
Old 05-05-2018, 04:46:04 PM
The hot tube should have a glow to it that is visible before trying to start it. If you feel the need to check it after it is running, please use a mirror to look down the chimney. We don't want bad things to happen. Did you insulate the chimney? I find that it really helps.
40 hp Bovaird and Seyfang mudcat16735 Oil Field Engines & Related Equipment 2 07-13-2011 10:20:02 PM
40 H.P. Bovaird & Seyfang Jeff Miley Antique Gas Engine Discussion 3 03-13-2008 08:25:36 PM
40 H.P. Bovaird & Seyfang Fred Van Hook Oil Field Engines & Related Equipment 3 01-09-2008 07:31:05 PM
Bovaird And Seyfang SteveK Oil Field Engines & Related Equipment 0 08-30-2007 09:20:37 PM
40 hp Bovaird & Seyfang $$$ ? OLDREDIRON Antique Engine Archives 1 09-25-2004 07:08:21 AM
