Jacobson Machine Mfg. Co., Warren, Pennsylvania
this thread has 396 replies and has been viewed 78026 times
Old 01-18-2014, 04:03:11 PM
Don Worley Don Worley is offline
Default Re: Jacobson Machine Mfg. Co., Warren Pa.
Testimonials-some of these are Pennsylvania engines. Large engines.
The Following User Says Thank You to Don Worley For This Post:
Old 01-19-2014, 10:23:36 PM
Factory photo showing fuel pump and Elkhart mag.
Does anyone out there have one of these fuel pumps?
The Following 8 Users Say Thank You to Don Worley For This Post:
  #243
Old 01-20-2014, 10:12:03 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Here are pictures of a recently restored 2hp. Bull's Eye. Don, note the original cart under the engine.
http://buzzcoil.brinkster.net/moody/page129.html
Denis Rouleau
The Following 3 Users Say Thank You to Denis Rouleau For This Post:
  #244
Old 01-20-2014, 11:15:32 AM
Denis Rouleau
...and I am sitting here marveling at the complexity of the ignition system, thinking about how easily it could be broken off and how troublesome it might be after receiving significant wear.
Denis, Don, and all who are contributing to this thread, I thank you.
Kirk
The Following User Says Thank You to Kirk Taylor For This Post:
  #245
Old 01-20-2014, 05:27:32 PM
Those Accurate mag and ignitor setups are huge. On a small engine they add inches to the front and obscure the front of the head. I imagine that many were broken off during moving even though they are more heavily built than the Webster.
The cart looks to be a possible original.
Tom; Thanks for sending in the pictures of your engine.
Old 01-20-2014, 11:33:23 PM
This is the same engine as my previous post.
The Following 2 Users Say Thank You to Don Worley For This Post:
  #247
Old 01-21-2014, 09:27:09 AM
Don, is there any usefulness to the underwriter's tag on a Jacobson engine? Was it a selling gimmick to show that a Jacobson was safer than any other engine make? Did not seem to be a requirement as other engines don't have underwriter tags.
Also, have you determined the importance or significance of the number on the tag? Tom's tag is #5, by far the lowest number found on an underwriters tag.
Denis Rouleau
Old 01-21-2014, 11:15:03 AM
It was a selling point. However, the obtaining of an Underwriters approval for an explosion-proof engine for use inside a building could also be a practical thing when it came to insurance coverage. You must remember that at this time gasoline engines were still not trusted as much as steam. If you had a steam boiler and engine, you needed a registered steam operator, which indicates that even steam was not totally trusted. Having a gasoline engine that had a special design for the fuel storage and delivery system, as the Underwriters approved tank that Jacobson used, would ease the worries of both the insurance company and the owners. The tank and fittings are definitely safer than the standard tank, having reenforced, riveted seams, spark proof screens in all the tank fittings and a special filling and venting system.
As far as I know, Jacobson is the only company that went to the effort to go through the testing to obtain UL approval. Whether Wards had any push to get UL approval is unknown, though it would seem likely for Jacobson to get the manufacturing contract among all of the engine companies at the time.
  #249
Old 01-22-2014, 08:19:32 AM
Picture of a UL tank under construction. All seams, rivets, fittings and corner gusset pieces are soldered together.
Old 01-23-2014, 12:33:25 AM
This is supposed to be portable. Note the fuel pump setup. Anyone got an engine with one of these pumps? The fuel pump is required because the carburetor is mounted high by the intake. Most were mounted low and were gravity fed.
The second picture shows an engine with a similar setup that has been made gravity fed. The bolt holes in the base indicate it probably had a pump.
ID:	185678   Click image for larger version
The Following 5 Users Say Thank You to Don Worley For This Post:
  #251
Old 01-24-2014, 11:11:27 AM
Here are some name tags found on Jacobson built engines:
http://buzzcoil.brinkster.net/moody/page130.html
Seems like it is not easy to take good pictures of name tags as I had to go through over 100 pictures of name tags to come up with just these few that are nice enough for here.
If you have or feel like taking a better picture of your Jacobson's engine tag, please do so and email me the tag's picture.
Thanks!
Denis Rouleau
ID:	185800   Click image for larger version
ID:	185801   Click image for larger version
ID:	185802   Click image for larger version
  #252
Old 01-25-2014, 10:21:57 AM
The most original Unito engine that I have seen. Don't know where it is now. When I saw it guys from Canada were trying to sell it.
  #253
Old 01-26-2014, 11:59:11 AM
Factory photo. Early hopper type Jacobson around 1912. You can tell by the cone muffler and the intake cage with the mounting bolt showing. This side of the cage tended to break off if tightened too much. The design was changed to make it solid on that side. This photo was taken during the Wards period so some Jakes were made during that time. You will note that it has a battery box and an Elkhart mag. The larger engines had both with a two way knife switch to start on the battery and then switch to the mag. You will also note bolts for mounting on a cart on the skid. This is the same engine that was previously shown on a cart. They forgot to put an oil cup on the front sideshaft mounting bracket. If you are restoring a Jake note the details to make the restoration correct. This is one of the best photos that I have for detail.
The Following 6 Users Say Thank You to Don Worley For This Post:
  #254
Old 01-27-2014, 07:19:47 PM
Last of the 7 hp pictures. I am running out of good stuff to post. Anybody got things to post?
I know that it is winter and engines are buried in corners, but we need more Jacobson serial numbers sent to Denis. Please register your engines.
The Following 3 Users Say Thank You to Don Worley For This Post:
  #255
Old 01-28-2014, 06:21:58 PM
I found one more 1912 engine picture. It shows a good view of the gas fill set up and early oil shield which is thinner than later design.
  #256
Old 01-28-2014, 08:37:36 PM
Bob Upham Bob Upham is offline
Don Do you know the reason or time period change as to why some engines have the air intake made from plumbing fittings vs the casting?
The Following User Says Thank You to Bob Upham For This Post:
  #257
Old 01-28-2014, 08:58:11 PM
The cast elbow appears to have started when the Wards engines changed names from "The Ward" to the Bullseye. I have a feeling that Wards probably thought that the pipe intake looked cheap and required a more ritzy appearing part. The cast elbow also worked better because it had a built in venturi. The Bullseye will not have pipe intake, but a Jacobson could have either.
The Following 4 Users Say Thank You to Don Worley For This Post:
  #258
Old 01-29-2014, 12:11:28 AM
Jeff Wahl's Avatar
Jeff Wahl Jeff Wahl is offline
How bout some pictures of a Jacobson model engine?
-Jeff
wahlengines.com
The Following 8 Users Say Thank You to Jeff Wahl For This Post:
  #259
Old 01-29-2014, 08:33:47 PM
This post and several following posts will be pages from a salesman's book 1908.
ID:	186405   Click image for larger version
  #260
Old 01-30-2014, 11:49:27 PM
Sales book continued 1908
ID:	186513   Click image for larger version
Machine shop in western Pennsylvania? J. Sutter Antique Gas Engine Discussion 3 09-25-2014 09:33:33 PM
THe Little Elgin-RA warren Tom Hartfield Small Air Cooled Gasoline Engines 1 03-05-2012 05:31:18 PM
Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES) Denis Rouleau Antique Gas Engine Discussion 10 06-18-2011 11:15:59 PM
WD-40 IH at J.B. Warren Sale Eric Best Antique Farm Tractors 0 09-23-2005 09:35:45 PM
