Another 72 Coil Question
this thread has 22 replies and has been viewed 3874 times
Old 08-06-2015, 05:21:13 AM
CLBetten CLBetten is offline
Default Another 72 Coil Question
I am assembling my first 72 D Eismann. The coil is to say the least not pretty. When I check continuity between the high tension terminals it is an open circuit. Also each high tension terminal to ground or hot to the primary winding is open. When I power the primary with 6 volts and one high tension grounded I get spark from either high tension output. I've read posts of people claiming their engines run fine with no continuity between high tension leads. Is my coil usable or would I be fooling myself to try it?
Old 08-06-2015, 01:38:20 PM
Default Re: Another 72 Coil Question
I've come to realize any spark I get must be from an arc making a way across an internal open circuit. I'm thinking its a core.
Old 08-07-2015, 11:14:39 AM
This problem was common to the D and Da coils. Zack Northway (a Stak Sponsor) has coils - not cheap). you might also try to contact Tom S. or Mark Shulaw, both members here on the Stak. They might have a coil, or know of a source. NOTE: you cannot mix the DA with the D - the iron cores are different, and the flywheel magnet ring IDs are different. You must stick with the D type your engine came with unless you switch both the mag, backing plate and flywheel.
I think mark was trying to have new coils wound, you might try him first.
Old 08-07-2015, 11:36:47 AM
I have considered the Briggs conversion. After more research it sounds like they don't run as well and are difficult to start. Mark isn't a fan of them. He may well have a source for original style replacements.
Old 08-07-2015, 01:29:13 PM
I spent a lot of time experimenting Briggs coils and found about the hard starting and poor running. I also tried something that hasn't been talked about. I put two single cylinder coils stacked on the Maytag armature. One side of each coil is grounded and one side is hot. I didn't get any better results.I have two Maytag twins with generators that I wanted running good so I finally bought two of Zack's coils ($150. ea.). They now run great! I just checked Zack's sales and he is no longer offering the coils. Check Ebay zkstuff I'll have to find out if he is going to have more made. He will be at the Portland show. (If the water isn't too deep). Ron
Old 08-07-2015, 04:35:00 PM
David M. Lyon's Avatar
Images: 32
This video may help to see if the coil is good
https://www.facebook.com/davidsolden...type=3&theater
Old 08-07-2015, 09:31:37 PM
Kevin Weis Kevin Weis is offline
Think he usually makes a certain number, waits till their sold out then makes more. I have a wico that has an open circuit but runs fine on yes, both cylinders. Don't know how long that's going to last though before it burns out.
Kevin
Old 08-08-2015, 05:11:57 AM
That's basically where I'm at. I'm not out anything to try it but have to expect it to fail at any time even if it runs. I liked the idea of the Briggs because it would be new. I take it then that the ones Zack sells are also?
Old 08-08-2015, 11:36:55 AM
After I got tired of experimenting with Briggs coils I left it go for a while. I'm still thinking about it and have some questions about the electronics. Would a different condenser or two work better? Will stronger magnets make it work? In other words why do they work in the Briggs engines and not in Maytag engines? CL did you get my email? Ron
Old 08-09-2015, 10:51:26 PM
Thought someone was experimenting with separating the two sections of bad coils and finding out that most of the dead (open circuit) coils were because the wire between the two sections was corroded. This was repaired and re-sealed and put back on the armature with good results. This sounds like too much trouble, but if new coils are stop being made, may be are only option.
Kevin
Old 08-10-2015, 02:00:37 PM
Turbo's Avatar
Turbo Turbo is offline
I have successfully repaired 2 bad coils by dissecting a few bad coils. I found that the main problem was corrosion between the two secondary coil halves. I removed the secondary coils and tested separate. I found two with 4,000 ohms resistance and soldered a new wire between. Reinstalled over the primary coil using liquid electrical tape. The engines run great. One thing to note is the corrosion problem is not limited to just the connection between the halves. I found some of the secondary halves had "green" wire far up into the winding, and tested open. The main problem with them in my opinion is bad insulation. Engines that were stored in a dry environment with no condensation probably still have functioning coils.
Old 08-11-2015, 12:40:55 AM
I finished mine. I have no spark. Briggs is apparently a bad investment. If they don't start and run well that's not a solution in my opinion. At the moment I'm stalled on my project.
Old 08-11-2015, 02:39:23 AM
I separated and cleaned my coils. I don't see a connection between the two whatsoever nor a lead to test the individual halves.
Old 08-24-2015, 04:07:30 AM
I found the wire ends. Both have open circuits. I think I'm just going to cut to the chase and buy new. Zack is out of them. They said they'd let me know when they are available. All my research has brought me to the conclusion that every other option provides marginal success.
Old 08-25-2015, 11:39:17 PM
CL, thinking your making the right choice. The chance you can find one on the internet that test good and will run well for any length of time are typically slim at best. I've been down that road several times. NOS coils are a rare bird as well.
Regards, kevin
Old 08-26-2015, 01:42:49 AM
Given the fact that they are apparently in demand I'm surprised the availability isn't better. Gives me something to look forward to I guess.
Old 09-02-2015, 09:42:14 PM
I received a call from Mark's crew. New coil on the way. I've spent more on this project than I can likely justify but it's a form of recreation for me. I see he has relisted them on EBay as well.
Old 09-03-2015, 09:37:59 AM
I didn't know that Mark had new coils. Is his price the the same as Zack's. Ron
Old 09-03-2015, 07:01:00 PM
I meant Zack.
Old 09-05-2015, 10:02:12 PM
coyote62ny coyote62ny is offline
zacks coils are very hot coils i have installed them in 3 maytag twins all 3 will start by fliping the flywheel by hand do your self a favor and get a new condenser as well
72 coil question edisondiamond Maytag Engine Collectibles 11 08-28-2016 11:10:41 PM
MSD Coil question Road Torpedo Antique Autos and Trucks 32 02-22-2013 01:37:35 PM
IHC M coil wiring AND (yes) another question Sky Antique Gas Engine Discussion 13 10-09-2009 06:52:53 AM
Coil Question trashman6062 Small Air Cooled Gasoline Engines 3 05-27-2009 05:20:37 PM
Buzz Coil Question wegotallama Antique Gas Engine Discussion 5 01-27-2009 10:22:18 PM
