Farymann Single Cylinder Diesel 22L0577
this thread has 1 replies and has been viewed 4730 times
Old 06-05-2009, 08:58:38 AM
JALaswell JALaswell is offline
Default Farymann Single Cylinder Diesel 22L0577
I have a Farymann Single Cylinder Diesel 22L0577 Air Cooled Diesel Engine. It is missing Sheet Metal, Valve Rockers, Push Rods and Output Shaft. According to Farymann USA many of the parts for this engine are no longer available. The Cylinder, Head, Rod, Crankshaft and block all appear to be in good usable condition. The cooling fan is cracked. I would guess at some time someone flipped the decompression lever while the engine was running since the problem appears to be with the valve train. Does anyone have any information on this engine such a Horsepower, year built range etc.
Since the engine is not usable in its present condition I would be glad to part it out or sell the complete engine if you have a similar engine and need parts. It is a very heavy engine and shipping would be expensive. Probably about 70 LBS.
Old 06-10-2009, 09:13:55 PM
Thumper Thumper is offline
Default Re: Farymann Single Cylinder Diesel 22L0577
I would watch ebay, every now and then you will see one. I think there are a couple of Farymann Diesels on there now, a V-twin just sold the other day that was beautiful for a $1,000.
here is a NOS with a tanny, but pricy;
http://tinyurl.com/mvetjf
Good luck,
Dave
Farymann / Briggs Single Cylinder Diesel JALaswell Vintage Diesel and Oil Engines 7 05-08-2009 02:31:42 PM
Single cylinder Homelite Diesel generator ID cummins88 Generators & Electric Motors General Discussion 2 01-09-2009 12:59:22 PM
Farymann diesel engine info Tom Geier Vintage Diesel and Oil Engines 3 10-06-2008 06:01:30 PM
Fairbanks Morse Model 45 - Single Cylinder Diesel Ted Rozanski Antique Engine Archives 0 07-29-2002 01:11:32 PM
Single Cylinder Diesel Onan Steve Onan Generators 0 10-14-2001 03:46:58 PM
