Go Back   SmokStak > SmokStak® General Discussion > Antique Motorcycles
Antique Motorcycles All about finding and fixing old motorcycle engines and vintage bikes.
Antique Motorcycles
Smith Motor Wheel
this thread has 1 replies and has been viewed 2046 times
Old 02-12-2016, 08:58:47 AM
Winchester Winchester is offline
Default Smith Motor Wheel
I'm rebuilding a SMW ,rebored the cylinder and made a new piston to suit ,made new rings ,two compression and one oil scraper. I made a new inlet valve cage and valve [ atmospheric valve] and fitted a suitable compression spring. Put it all back together and set it up with an electric motor to run it in . After an hour or so still no compression ,checked everything ran it again ,no compression ........I had a think about this and I reckon that the inlet valve spring [ atmospheric] is too strong . The valve is not opening enough and I am running a partial vacuum ,hence no compression ....am I correct. there is one way to find out but I've not got around to changing to a much weaker spring yet.
The Following User Says Thank You to Winchester For This Post:
Old 02-12-2016, 09:38:24 PM
Junkologist's Avatar
Default Re: Smith Motor Wheel
You will definitely have a lack of compression if the intake valve will not allow air in. Can't have compression if there's no air to compress. Some air compressors unload the compressor this way by not allowing any air to be taken in.
You can check your engine out by simply removing the spark plug and turning the engine over until the piston is at BDC between the intake and compression strokes. Put the plug back in and turn the engine over. If everything is ok and there are no leaks, there will be compression as soon as the piston starts to go up the bore. If your intake valve spring is too stiff, there won't be any compression after that. The intake valve should also be making a snorting or rattling noise if it is working properly.
Mike
SmokStak member #146
Smith Motor Wheel jopeter Smokstak Down Under 14 11-29-2017 06:24:36 PM
Smith Motor Wheel... help please! jopeter Smokstak Down Under 13 03-18-2014 11:36:36 PM
Smith Motor Wheel help Tom Manley Small Air Cooled Gasoline Engines 1 09-20-2009 07:51:56 PM
smith motor wheel. bill schaller Antique Engine Archives 1 04-13-2002 07:53:50 AM
smith motor wheel ray webb Antique Engine Archives 0 06-12-2000 04:27:00 AM
