Air Compressors
Pneumapower 35 Compressor
this thread has 4 replies and has been viewed 452 times
Old 09-01-2018, 08:20:48 AM
oakjcm oakjcm is offline
Default Pneumapower 35 Compressor
Do you have manuals for pneumapower 35? I have one and know nothing about them
except their from the 50's and I would assume they use 20w non detg. oil
Old 09-01-2018, 05:26:17 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Default Re: Schramm Tow-behind Air Compressor
I tried to post this earlier and failed, so try again. We have a large unit on a 4 wheel chassis, it has a Large 6 cyl Buda engine with a clone 6 cyl compressor hooked up via a over center clutch. I forget the model but it is a big unit . I need to get it going before the thing goes to ruin. I got it out of a cement plant and they used it to spray concrete on like silos and the like. I didn't get the spray kit as the guy thought it was worth it's weight in gold, so
I just got the compressor unit. Any books or parts still around? I don't totally understand the pressure governor and how it works, thing has a relatively small volume tank for the size unit. I kinda thought
I could use it to run a steam traction engine here that needs a boiler, it has plenty of capacity if I can get it going.
Old 09-02-2018, 11:20:13 AM
Jim Arras's Avatar
Jim Arras Jim Arras is offline
Default Re: Schramm Towbehind Air Compressor
Replied to your PM.
Old 08-12-2019, 05:33:11 PM
Hey Jim Do you have gasket sets for the schramm 35 or a block to jug gasket& head gasket Mine has sprung a leak, looks like it's coming from the engine side between block and jugs. also does anybody know why I'm getting carbon out of the compressor side? Thanks Jpohn
Old 08-12-2019, 10:15:11 PM
Jim Arras's Avatar
Default Re: Pneumapower 35 Compressor
I should have the gaskets, sets are no longer available.
1950 & 1952 SCHRAMM 35 Pneumapower Compressors - Wisconsin VM4/VP4 K-Tron Wisconsin Engines 22 06-21-2019 10:32:13 PM
Emmerson Compressor Motor Needs Part to make compressor run again. Kanoona Air Compressors 7 10-14-2017 06:49:36 AM
Novo Air Compressor - HB Compressor? BigGoomba Hit & Miss Gas Engine Discussion 3 10-30-2015 10:15:31 AM
Leo compressor: Trying to identify a small compressor unit MattFretwell Unidentified Engines 1 02-27-2012 07:01:50 PM
Air compressor Lyle Fall Antique Engine Archives 0 09-07-2004 08:46:08 PM
