Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
YouTube Old Iron Videos A place to show your ON topic movies of antique engines and old iron.
6 in Atlas Lathe Compound Slide Pattern
this thread has 7 replies and has been viewed 1309 times
Old 04-17-2018, 02:39:44 PM
old iron shops old iron shops is offline
Default 6 in Atlas Lathe Compound Slide Pattern
I started a new project. I'm converting a 6 inch atlas compound slide into a foundry pattern I'll be posting get up weekly if you are interested in how this is done have a look here
https://www.youtube.com/playlist?lis...09eTCsplehC404
Old 04-17-2018, 04:32:19 PM
Default Re: 6 in atlas lathe compound slide pattern
If you raise the pad the AXA tool holder mounts to, would you not then have to lower the tool to get it back on center, thus putting it back at same height where it hits the compound rest?
Considering the steady supply of Atlas parts on ebay, why would you decide to cast them? Of course if you can start reproducing all the parts and get price down low enough to stop the parting out of the old machines that would be ok with me
Old 04-18-2018, 11:51:59 PM
i'm not sure i understand but the pad only needs to be maybe 1/8" height so the toop post can rotate fully . i think the tool blocks have enough adjustment to make this work fine
the reason im making them is i have a customer with steady business selling them already. he makes them out of steel but it doesn't have the same look as the oem parts and he would like to have the modification as a option . another benefit is its not worn out and of course we are saving good machines frome getting parted out . i not a big fan of that . i will spend more to reproduce my self a new part rather then dismantle something that is still working.
Old 04-20-2018, 11:48:05 AM
Default Re: 6 in Atlas Lathe Compound Slide Pattern
hey guys and gals the second video is up if you haven't see it yet here it is https://youtu.be/oCHhZD4xEdc
Old 04-27-2018, 11:25:59 AM
i have another video up on my patterns making project if you'd like to see here it is. https://youtu.be/VfUK9rVD1vI
Old 05-05-2018, 11:01:53 AM
here's the 4th video on this series https://youtu.be/bxeRdz_FJeQ
Old 05-11-2018, 01:00:58 PM
OK video #5 is up shows 5he assembly and painting of the Atlas 618 compound slide pattern hope you enjoy . https://youtu.be/epH3hbthCfE
Old 05-18-2018, 11:56:49 AM
OK patten is done let's try it in the sand and see how she draws
https://youtu.be/9d5pgDgQaqc
Atlas Lathe Jerry B Machine Shop and Tool Talk 7 01-19-2018 09:44:28 AM
Atlas 12'' 36'' lathe Jerry B Machine Shop and Tool Talk 10 10-15-2015 05:05:50 PM
Atlas lathe Jerry B Machine Shop and Tool Talk 4 08-19-2015 12:40:52 AM
Atlas Lathe Jerry B Machine Shop and Tool Talk 11 02-15-2015 03:38:44 PM
Setting the lathe compound flasks Scale Model Engineering 6 10-13-2008 10:30:48 AM
