Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag 72 governor spacer?
this thread has 2 replies and has been viewed 686 times
Old 10-08-2018, 04:35:26 PM
Zuma Zuma is offline
Default Maytag 72 governor spacer?
I’m not sure how or where it goes. I assume it goes on the spring end (stretch the spring,put on the spacer then the cap)but I haven’t a clue if that’s correct. Also how far in should I have the bottom plug? Right now it’s In just enough to clear the block but I also don’t know if that matters or if the adjustment should all be from the top end.
Old 10-12-2018, 01:29:37 PM
Default Re: Maytag 72 governor spacer?
The governor adjustment on the 72 is only made by screwing the plug on the crankshaft in or out. Generally even with the surface of the crankshaft is close to what it should be. I'm assuming the "spacer" your referring to is the brass body of the governor that attaches to the spring that attaches to the screw plug. The spring should not be stretched or altered at all. Hope I'm not missing something but others can chime in if I am. Kevin
Old 10-12-2018, 01:54:04 PM
Here is a listing from flywheel supply that shows the spacer and the way I described it going
https://rover.ebay.com/rover/0/0/0?m...2F111390462732
I assume that’s the way it goes because I put on and in but it just kept unhooking and falling off but I’m not sure.
Maytag 92 Pot Metal Governor what can you tell me about them. WesleyGrissom Maytag Engines and Collectibles 1 07-22-2014 08:47:03 AM
Elgin / Maytag governor Kevin Weis Maytag Engines and Collectibles 1 07-27-2013 01:48:30 AM
Maytag Upright Odd Governor Christopher Markley Maytag Engines and Collectibles 3 11-27-2011 02:27:59 AM
Maytag 72 Governor Screws Bigjoedo Maytag Engines and Collectibles 3 05-14-2011 08:27:22 PM
Maytag Ring Spacer? Joe A Antique Engine Archives 4 07-22-2003 04:13:22 PM
