Briggs & Stratton 5S & Model Y help
this thread has 16 replies and has been viewed 1111 times
Old 11-11-2018, 11:38:20 PM
Cnew Cnew is offline
Default Briggs & Stratton 5S & Model Y help
Hello,
Iím new to the forum and new to these older Briggs engines. Iím guessing these questions have been asked before but I could use a little advice. Is it good to add lead additive to todayís fuel? I have access to non-oxy at the local station. The manual calls for SAE 20 oil, is SAE 30 ok or should I look harder for specialty oil? What is the best way to remove the flywheel without damaging it or the crankshaft? It looks like the magneto coils are no longer available, does anyone know of a good replacement? Thank you for sharing your expertise!
Old 11-11-2018, 11:45:20 PM
ulgydog56's Avatar
Default Re: Briggs & Stratton 5S & Model Y help
use a hermonic wheel puller for the flywheel, they still sell dead 20 wt oil...low compression engines can use leadfree gas,if u want to use instead of lead additive it wouldnot hurt..autozone
Old 11-12-2018, 08:07:09 AM
Thanks for the suggestions. Normally I use a harmonic balancer for flywheels but the flywheel on the 5S doesnít have any threaded holes on each side if the crankshaft to mount the puller. Hoping there are some other tricks. I have a similar situation on an old 4hp Kohler.
Old 11-12-2018, 09:16:32 AM
FlJim FlJim is offline
First off, as I recall, the retaining nuts are left hand threaded. On removing the flywheel, I have removed many of them by applying pressure (don't be too aggressive) under the flywheel and with the nut screwed almost all the way down, strike the nut sharply and squarely on the end of the crankshaft. You need more than a tap with the hammer to break it loose and likely will have to hit it more than once. Good luck!
Old 11-12-2018, 12:23:38 PM
Turbo's Avatar
Turbo Turbo is offline
I second what FLJIM says. On the 5s thread the nut back on and strike the end of the crankshaft while applying pressure to the flywheel with your other hand. The Y is different as it is not a taper shaft. It uses a strait shaft with a bolt through the center to secure. They can be stubborn. I lock the crank with a pipe wrench on the pto end then try to spin the flywheel off. These engines are very common and parts are plentiful. Finding a good coil is no problem. I think I have a dozen or more of each coil laying around. I don't live too far from you in New Prague. PM me if you need any info or parts.
Old 11-12-2018, 05:00:40 PM
Mike in NC's Avatar
We use a tool just like this one in the link. They work very well.
We run SAE 30W oil in all of our engines.
Flywheel Tool
SmokStak Member #28
Old 11-12-2018, 08:29:50 PM
Junkologist's Avatar
Be sure to use a brass, copper, or lead hammer when striking the end of the crankshaft. A steel hammer will damage it.
SmokStak member #146
Old 11-13-2018, 02:31:40 AM
Ogrebeast64 Ogrebeast64 is offline
The older engines like the 5s and the Y do not have the hardened valve seats, so I would recommend using the lead substitute to keep from damaging the seats. I've got an old Model 8 (manufactured in 1951) I restored, and only use the non ethanol in it with lead substitute.
Old 11-13-2018, 08:13:30 AM
Thank you all for the great advice and tips. Iím anxious to give these a try and see what happens.
Turbo,
I may take you up on the parts offer once I get deeper into this engine and know whatís going on with it. If youíre interested I ugh thanks be interested in buying a coil from you just to have it on hand. I havenít tried to fire the Y yet, I need to get a gas tank for it. I think it has spark. It doesnít have the kick lever, looks like someone tried to convert it to a rope start and Iím actually thinking the pulley they used is backwards. Should the model Y engine rotate clockwise or counterclockwise?
This is an addictive hobby! Yíall are great!
Old 11-13-2018, 12:28:51 PM
Turbo's Avatar
Clockwise as you are facing the flywheel.
The Following User Says Thank You to Turbo For This Post:
Old 11-13-2018, 02:05:33 PM
Andrew Mackey Andrew Mackey is online now
Exclamation Re: Briggs & Stratton 5S & Model Y help
Back when these engines were built, tetra ethyl lead was still not common in gas. Unleaded won't hurt, as these are relatively low compression (5:1), low speed (under 3000 RPM) engines. They are not high compression auto engines! No alky fuel is good, I would run high test if you use alcholized gas. SAE 20 is available from Tractor Supply, and some auto stores. You may have to ask for it if you do not see it on the shelves. SAE 30 Ok for most, if above 40F. Below that, you must use the SAE 20 or even 10W-30. DO not use SAE 30 in the WI with the oil pump - it is too thick for the pump to operate properly. Don't use the 10-30 in the summer - too thin!
Old 11-13-2018, 09:19:08 PM
Thank you Turbo, glad I asked- the pulley that is on the engine now definitely has it turning counterclockwise.
Old 11-13-2018, 11:26:18 PM
Ken Karrow Ken Karrow is offline
20 weight should be at any decent farm supply if you do not have TSC. Back in the day we used to go to the marina to get marine white gas for mowers. Dad claimed run cleaner in the little briggs. I believe it was no lead, octane was low enough that a stock '48 Chevy would knock on it when pulled at low rpm.
Old 11-14-2018, 05:48:23 PM
'White Gas' is like Colemens fuel - only about 50 octane. It does burn clean though. As you found out, it will knock if heavily loaded in an engine. Lucky you didn't hole a piston! Most marine engines were cooled directly from the lake or river water that was available, which made them run very cool - no thermostats like in a car. You could get away with a lower octane in a cold running engine - it wouldn't get hot enough to knock! Also, marine engines almost never get to be heavily loaded like a car engine, unless they were mated to a propeller that was too large for the engine.
Old 11-18-2018, 07:48:01 AM
Default Re: Briggs & Stratton Model Y help
Once a Model Y is running, what is the proper way to shut it down? My engine doesn’t have any sort of kill switch or tab that you touch to the spark plug. I plugged the air intake with my finger which worked but that doesn’t seem like a good thing for the engine.
Old 11-18-2018, 11:52:03 AM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Short the plug out with a screwdriver to ground.
Old 11-21-2018, 10:26:18 AM
If you all are able to get SAE 20 in your area you might want to stock up. Definitely not available where I’m at. I checked TSC as well. Only straight grade they can get is SAE 30. Other than that it’s multi weight or synthetics.
What model Briggs and Stratton is this ? Dick Graybill Small Air Cooled Gasoline Engines 5 11-18-2017 09:15:53 AM
Briggs Stratton model 23 Mike Cannon Small Air Cooled Gasoline Engines 9 05-14-2016 04:33:29 PM
Briggs & Stratton Model Y dirtycurt Small Air Cooled Gasoline Engines 1 11-28-2011 09:16:10 AM
Model 14 Briggs & Stratton venom4me Magnetos, Ignition Coils and Spark Plugs 4 11-27-2011 11:59:12 AM
Value of a Briggs And Stratton Model I Hit and Miss kid Small Air Cooled Gasoline Engines 11 07-29-2008 10:42:44 AM
