Need Information on Reo Engine
this thread has 10 replies and has been viewed 4147 times
Old 05-13-2009, 12:27:37 AM
Floyd C Floyd C is offline
Question Need Information on Reo Engine
I have a small engine like I have never seen before,would like to have information on.
The tag says Reo Motors Inc. Model 211 Type E1 Serial Number 35197.
It doesn't say what horse power it is.It has a reverse gear made into it,the engine turns one way and the pulley turns the other.The cyclinder sits at a forty five degree angle.
Old 05-13-2009, 01:30:05 AM
Meco3hp's Avatar
Meco3hp Meco3hp is offline
Default Re: Need information on Reo engine.
Floyd,
You have a 1951 Reo. It should have a flat gas tank, automatic rewind starter, mesh type air cleaner, 2 to 1 gear reduction. Its rated at 1-3/4hp @ 4000rpm. I picked one just like it up at a auction 2 weeks ago. They are good runners! All reos are slant cylinder engines with different carb/fuel tank/starter set ups. I've got a manual, if you want a copy.
Thanks!
Richard
The Following User Says Thank You to Meco3hp For This Post:
Old 05-13-2009, 01:55:43 AM
Exclamation Re: Need information on Reo engine.
You can also check Erv Troyer's Web site http://reoengine.us/ Irv has REO production records.
Andrew
Old 05-13-2009, 07:24:44 AM
Craig DeShong's Avatar
Craig DeShong Craig DeShong is offline
All the REOs are built with the PTO coming of the camshaft, this is why the drive shaft rotates in a different direction than the engine and has a 2-1 reduction.
[I]My Photos
The Following User Says Thank You to Craig DeShong For This Post:
Old 04-06-2014, 10:48:41 PM
jackthetoad jackthetoad is offline
You can find info on REO engine repair and engine parts lists at
www.michiganssmallengineresources.com
The Following 2 Users Say Thank You to jackthetoad For This Post:
Old 05-14-2018, 01:48:02 AM
Tyler J. Tyler J. is offline
If you have a manual for a Reo 211 E-1, could you please mail me a copy of it to: Justin Keffer, 347 Hairetown Road, Jonesborough, TN, 37659? Would be very much appreciated.
Thanks.
Old 05-14-2018, 07:05:32 PM
Ken Karrow Ken Karrow is offline
You have noticed I'm sure the crank turns backward to normal but the pto is normal. Smart engineering since you got the first step of speed reduction for free since you have to buy a cam and crank gear anyway. Sweet running little engines. Air cleaners are hard to find.
Old 08-28-2019, 08:34:46 PM
52655 52655 is offline
Default Re: Need Information on Reo Engine
Anyone know the colors of a REO reel mower?
Model number 211f 1952
Old 08-28-2019, 10:40:45 PM
ulgydog56's Avatar
sounds like a reo royal (I have one) the deck is pained cream white and the engine and tank is a sea foam green..
Old 08-28-2019, 10:42:10 PM
ulgydog56's Avatar
[QUOTE=52655;1600057]Anyone know the colors of a REO reel mower?
Model number 211f 1952[/QU. should have a pic, just click on my name and find it in my pics.....
Old 08-29-2019, 07:36:34 AM
SparkyMil SparkyMil is offline
52655, Take a look at enginads, I have one listed for sale and should show the colors very good.
IHC T35 engine information Gasengin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 01-01-2015 10:29:59 PM
Engine Information Carolyn Hit & Miss Gas Engine Discussion 3 09-07-2012 11:05:46 PM
Information on a engine P Grogan Hit & Miss Gas Engine Discussion 3 06-29-2010 01:32:02 PM
Need information on a 4hp CH&E engine Chuck Woycke Hit & Miss Gas Engine Discussion 5 04-23-2008 05:53:45 PM
Engine Information??? mike Smith Antique Engine Archives 10 11-27-2003 01:58:26 PM
