starting an old briggs?
this thread has 16 replies and has been viewed 2109 times
Old 07-28-2007, 01:43:59 AM
Kyle McGee's Avatar
Kyle McGee Kyle McGee is offline
Default starting an old briggs?
hey evryone
my uncel gave me a old briggs and a air compreser and i have made it a skid and i have just finished wiring it and cleanign the carb and it souns weird but how do i start it im gessing that its a crank of some sort but i dont have one so i figured i would ask if there is any other way thanks kyle mcgee
here are some pics of it
Old 07-28-2007, 01:45:44 AM
Kyle McGee's Avatar
Default Re: starting an old briggs?
oh and i will go out to the shop and get the sireal # tomarow if it helps
thanks kyle m
Old 07-28-2007, 03:36:35 AM
Jester Jester is offline
Hi Kyle.
You are right, Briggs made a crank handle to fit that pinned shaft sticking out the front of your blower housing. Your engine was started by first slipping the crank handle onto the shaft & engaging the slots in the handle hub with the pin running through the starter shaft. You then pushed handle and starter shaft/ring gear into the hole in the blower screen so the ring gear will engage the pinion gear on the end of the crankshaft. That's the obvious part to starting this engine. If you look carefully at your posted pictures, you will see a bent over 3/16" rod sticking through the top of the blower housing on the left(carb.) side. This rod is the most visible part of the compression release--the next step in the starting process. The operator would set the choke, pull the comp. release lever up and hold, and turn engine over several times with the crank to build up speed in the moving parts. After enough momentum was achieved, he would release the spring loaded lever and continue cranking until the engine started. After startup, operator would remove crank from starter shaft and set it in a handy place, open choke, set throttle to desired speed, etc. As you have already observed with your project, most of the time the handle is no longer with the engine when it is rediscovered. You might try posting a wantad in the enginads, and there are some people on the vendor pages who might also be able to help. In the meantime, you could belt this engine to a small HP motor or another small engine to try to start it. This should be done in a way that allows the belt tension to be released and the belt removed after engine has started. If you can't picture a safe way to do this, please don't follow this suggestion--there is potential here for a real tragedy if this is done wrong!! As a safer and simpler alternative,you could also take a 4' length of starter rope with a handle & wrap the loose end around the belt pulley. In any case, I'd take the belt connecting the engine and compressor off before trying anything .
Jester
Old 07-28-2007, 09:56:09 AM
Kyle McGee's Avatar
thanks jester i think im guna try and make a crak and try and get the old girl going today
Old 07-28-2007, 11:11:47 AM
John Newman, Jr.'s Avatar
From what I have seen, original crank handles are kinda hard to come by and a bit pricey when you do find one. I have made starter crank handles from mill vise handles. You have to make an adapter with a square shank that will press fit in the handle. I will try to post a picture of one of mine later.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 07-28-2007, 12:30:58 PM
Kyle McGee's Avatar
ok thanks jhon
Old 07-28-2007, 02:04:00 PM
Kyle McGee's Avatar
well i made a crank i used some 3/4" black pipe and gut it to about 5 " then notched it out to fit over the crank of the motor then took some 5/8 rod and heated it up and bent it on a 90 and then drilled a hole in the black pipe and welded it... its not purddy but it work i will make a better one but i just want to get the old girl going
now to find some gas line then to see if she comes to life
Old 07-28-2007, 06:15:14 PM
Here is a picture of my vise handle crank.
John Newman, Jr.
Saint Louis, MO
Old 07-28-2007, 07:57:50 PM
Kyle McGee's Avatar
wow that looks good im guna make something liek that but the farmer rigged handel i made is working so far lol
Old 07-28-2007, 08:06:52 PM
That's a real stout looking handle, John. Adding the adapter gets the swing end of the handle a little farther away from the blower housing and starter bracing--I like that, too! I'll have to keep my eyes for some of those handles at the local flea markets.
Old 07-28-2007, 08:18:37 PM
Kyle McGee's Avatar
if i post the serial # would someone be abel to tell me what year the motor is thanks kyle m
Old 07-28-2007, 09:37:27 PM
If we tell you all the answers, how will you learn, Grasshopper?
The information you seek is available at the following site (among others):
http://www.flywheelers.com/pages/BobLearned/tekdata.htm
My guess is that your engine is a Model Z or ZZ. The build dates for this model is at the bottom of the page. You will also find lots of other good stuff about old Briggs.
Good luck & have fun.
John Newman, Jr.
Saint Louis, MO
Old 07-28-2007, 10:50:32 PM
Kyle McGee's Avatar
ya on the briggs tag it sais its a ZH
well it fires but dousnt want to run but i will tinker around with it tomarow in the day light
thanks for all your help jhon!
Old 07-29-2007, 12:39:23 AM
Kyle McGee's Avatar
here is the crank i made for it tonight
Old 07-29-2007, 01:58:42 PM
Sky
Dont know if you already know this or not but i think you'll find once you get the ZH running, they make for REALLY fine idler's. with a carb finely tuned and the crack screw set JUST right,...you got yerself a nice low RPM idler.
Old 07-29-2007, 02:35:48 PM
Kyle McGee's Avatar
ITS ALIVE!!!!!! MUAHAHAHAHA
ya lol i just found out it idels really nice lol movie is loading right now!
Old 07-29-2007, 03:37:45 PM
Kyle McGee's Avatar
Briggs starting info needed. EvilDr235 Small Air Cooled Gasoline Engines 5 05-05-2015 11:48:26 AM
Briggs crank starting ... KidDynamo Small Air Cooled Gasoline Engines 11 12-30-2009 05:54:10 PM
Briggs model A starting problem Arlie Levy Small Air Cooled Gasoline Engines 3 06-08-2009 12:10:19 PM
Briggs and Stratton starting problem nitro74cs Small Air Cooled Gasoline Engines 7 05-20-2009 05:47:12 PM
Starting Briggs AP wrsherman Small Air Cooled Gasoline Engines 4 03-20-2008 09:25:46 AM
