What make is this?
this thread has 5 replies and has been viewed 2725 times
Old 05-12-2012, 07:56:59 PM
6ary 6ary is offline
Photo What make is this?
Anybody know what this is.... make or model
Name:	May 2012 008.jpg
ID:	135189   Click image for larger version
Name:	May 2012 011.jpg
ID:	135190   Click image for larger version
Name:	May 2012 010.jpg
ID:	135191   Click image for larger version
Name:	May 2012 009.jpg
Old 05-12-2012, 08:32:35 PM
Default Re: What make is this?
Its a motor-generator,maybe for phase conversion or just voltage drop.
The Following User Says Thank You to Ed Radtke For This Post:
Old 05-13-2012, 12:35:04 AM
John Newman Jr.'s Avatar
John Newman Jr. John Newman Jr. is offline
Note the shaft that is not connected to anything. Motor/generator power supply usually doesn't have that. Looks like it could be a 2 bearing generator to me. Meter only goes to 50 amps, so output would be less than 12,000 watts at 240 VAC. About right for the size of it.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
The Following User Says Thank You to John Newman Jr. For This Post:
Old 05-13-2012, 10:02:10 AM
Arkie Arkie is offline
I agree with John! Also notice the ammeter appears to be marked at around 25 amps, therefore may be around 6kw, also see what appears to be 3 wire output leads, most likely 120/240 single phase, but would not rule out 3 phase.
I would do some serious insulation testing with a megger before spending any other time on the unit.
I would also save those Simpson meters, as they are the cadilliac of industrial meters, last forever if not mistreated of meters and the ammeter has a shunt associated with it so keep it with the meter.
The Following User Says Thank You to Arkie For This Post:
Old 05-14-2012, 03:46:58 AM
magnicon magnicon is offline
javascript:;
Pretty sure that was made by Brush,There is a smaller one on Ebay coupled to a Petter engine.Sorry I could'nt get the link to work.
http://ebay.co.uk/sch/Stationary-Engines-/58177/i.html
Try this!.
The Following User Says Thank You to magnicon For This Post:
Old 05-14-2012, 10:13:11 PM
moteurdelco moteurdelco is offline
yes, it's aBRUSH british made probably fit with a PETTER AV2 ;12 hp at 1800rpm
made in the fifties voltage regulated with 2 (or 3?) sets of dc brushes
many were 115vac ,or 115\230v with 4 slip rings
The Following User Says Thank You to moteurdelco For This Post:
What make is it? Barnbikes Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 15 12-08-2011 01:48:52 PM
What Make Is This Saw? Junkologist Chain Saw Collectors 1 05-31-2011 01:48:42 AM
What make is this one? BobM Hit & Miss Gas Engine Discussion 5 02-16-2008 12:06:47 PM
did they make? Chuck R Machine Shop and Tool Talk 2 05-12-2006 08:07:15 PM
what make is this mag? lauren langdon Antique Engine Archives 6 05-20-2004 06:38:02 PM
